Old 04-29-2020, 05:25 PM   #1
Ziegelsteinfaust
Re: C NOTCH or no C NOTCH
There are 2 ways to do a C-notch, and total drop depends on a couple of factors.
Some cut the frame, and weld in the C about 1/2 to 2/3's of the frame height. The higher you cut the more reinforcement you will need.
To the above. Depending on how high the bed sits above the frame in that area. Its a good idea to weld thick wall square tube there to reinforce the span.
At ride height in my opinion for a cruiser you want 2" minimum between the top of you 3rd member, and bed floor. I prefer 3" for most builds.. My 2018 uses baby soft bump stops, and would find similar. Especially if you want to run really low.
I have built a truck with just over a 1" gap between the 3rd member, and bed floor. While usually not bad. Every once in a while it would be quite the ride. We put small RE5 airbags in back along with fill caps in the bumper to fill them up with a bicycle pump.
Ziegelsteinfaust is offline   Reply With Quote
