Old 04-27-2020, 12:51 PM   #1
Bryan_C
1974 Suburban Tailgate Question
Hi - Has anyone removed this fiberglass(?) part that goes between the tailgate window and the body on a 1974 Suburban? I would appreciate any advice on how to safely remove and re-install this piece. Thanks!
Bryan_C is offline   Reply With Quote
Old 04-30-2020, 06:57 PM   #2
demian5
demian5's Avatar
Re: 1974 Suburban Tailgate Question
I'm gonna stick my neck out that if you pull the window seal there are bolts or screws in there. Look at a barn door truck and you can see what it can possibly bolt to.
I had them, but never pulled that off.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-30-2020, 07:34 PM   #3
Keith Seymore
Keith Seymore's Avatar
This is correct.
I think you remove the LH and RH side pieces first and then the center.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-07-2020, 12:31 PM   #4
swissarmychainsaw
and you will likely destroy the seal when you remove.
LMC has them though.
swissarmychainsaw is offline   Reply With Quote
Old 08-02-2020, 12:33 PM   #5
Bryan_C
Here is what I found: Remove the upper glass run felt, remove the screws for the tailgate seal, then you can remove the sheet metal screws holding the three pieces in place. Keith was correct - remove the side pieces first then the top. There is a rubber seal between the fiberglass parts and the body.
Note: The 1973-74 Suburbans use a separate upper glass felt run and a separate lower tailgate rubber seal. The 1975+ Suburbans use a one-piece felt run/tailgate seal.
