Old 04-24-2020, 11:48 PM   #2176
halfstep
Re: How to: Ruin a perfectly good C10
Thanks.
halfstep is offline   Reply With Quote
Old 04-26-2020, 06:53 PM   #2177
gringoloco
A guy with a truck
gringoloco's Avatar
Lotsa time, little progress. Finished press-rolling the sound deadener, then moved on to installing double-foil backed jute, then started laying some carpet. Cutting the little bits of insulation on the driver’s side of the firewall was tedious; not looking forward to laying the carpet in that area...
Good news is the high-hump carpet “fits” even with all of the floor modifications. Bad news is I think I want blue carpet instead. Hoping with a black bed floor, core support, inner fenders, and under-hood, that the black flooring will tie in better.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-26-2020, 11:05 PM   #2178
3757chevy
3757chevy's Avatar
I like the black. But it's your truck. And a Beautiful one at that.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 04-26-2020, 11:10 PM   #2179
gringoloco
A guy with a truck
gringoloco's Avatar
Much appreciated. It’s growing on me. I don’t hate it, just not sure I like it, yet
-Chris
Old 04-26-2020, 11:19 PM   #2180
nlped
nlped's Avatar
The black will disappear once you get the rest of the interior in there. That being said, I’m going blue in Walter.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-27-2020, 12:38 AM   #2181
SCOTI
SCOTI's Avatar
Gringo & Niped..... Question for you both: How much 'resistance' do your PB arms have w/the Delrin bushings? I partially assembled one upper & was surprised w/how hard the arm was to cycle through the travel.
The bushings required more force than I expected to get them seated on the cross-shaft. I feel like the welding process tweaked the arm enough that its in a bind.
Either of you note anything like what I'm describing?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2020, 07:56 PM   #2182
gringoloco
A guy with a truck
gringoloco's Avatar
That’s what my wife said, too. I’m rolling with it for now. If I hate it, it will get replaced...
Yep, actually had a bit of an issue getting it all together due to the tight clearances and ended up emailing Nate. He said that in extreme circumstances, one may have to use a bottle jack or porta-power to spread them back out a bit. If you try to force bolting them on, it could exacerbate the issue by folding the arms inward. Letting them relax bolted in position on the truck for a few months (years?) now, they are moving very smoothly. Maybe driving a few times and cycling them helped to settle everything
-Chris
Old 04-27-2020, 10:36 PM   #2183
SCOTI
SCOTI's Avatar
That definitely does not give me the warm & fuzzies.
The upper bushings spin freely on the arms cross- shaft.
The upper bushings fit within the bushing 'cups' on the arm.
Combine the two & now things dont align requiring them to be forced together.
While waiting for some insight on the uppers today, I messed w/the drivers side lower. Of the 4 bushings I tried on the lower drivers arm, one slipped right in w/zero effort & had some 'wiggle'. A 2nd pushed in w/my palm (it had less 'wiggle'). The other 2 require more force (c-clamp) but seem like they'll seat as needed. I pulled the sleeve & bolt from the ART arm on the truck now & both seemed they had a proper fit within the Delrin bushings.
I'll assemble & test installation fit to the DM of the lower arm tomorrow using the 2 easier to install of the 4 bushings.
Not sure what my approach will be for the upper. It should go together & not be in a bind. I'm not going to settle for anything less.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-28-2020, 10:48 AM   #2184
nlped
nlped's Avatar
I don’t remember having any issues, but it’s been a LONG time ago.
Carter
Old 05-02-2020, 08:40 PM   #2185
gringoloco
A guy with a truck
gringoloco's Avatar
So, this truck needs three, count ‘em three (3) shift boots. 1) to fit over the shifter itself to keep dirt and whatnot out, 2) to fit around the shifter base to keep dirt, rain, and whatnot out of the truck, and 3) to fit on top of the carpet and around the shifter handle to make it all look presentable.
Number one came with the transmission and number three will be a “stock” type oval boot. Number two required some creativity. I took a Mr. Gasket boot, cut off the top, flipped it upside down to fit around the shifter base, and bolted it to the floor. The boot itself is pretty decent quality, but the supplied ring and fasteners are a joke. I stuck 4 additional screws in it to help squish the boot into a reasonably sealed gasket. Excessive? Maybe, but it should help to keep the carpet dry...
-Chris
Old 05-02-2020, 08:54 PM   #2186
gringoloco
A guy with a truck
gringoloco's Avatar
Thankfully all that shenanigans disappears under the insulation, carpet, and inside boot (ordered a new one that’s hopefully not ripped and brown)
-Chris
Old 05-02-2020, 11:29 PM   #2187
SCOTI
SCOTI's Avatar
How are you securing boot #3?
Is each layer anchored to the floor?
Looks clean!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-03-2020, 12:11 AM   #2188
gringoloco
A guy with a truck
gringoloco's Avatar
Looks clean!
Thanks Scoti. #1 is a tight slip fit over the shifter stub and base, #2 is screwed into the high hump, and #3, the ‘decorative’ boot is just sitting there for now, as I used the trim ring on the grey Blazer before I sold it. A new boot is ‘in the mail’ with a new ring which will get fastened to the hump with some stainless sheetmetal screws (maybe the same ones that were holding it on before with the Lokar, if I can find them).
-Chris
Old 05-09-2020, 07:15 PM   #2189
gringoloco
A guy with a truck
gringoloco's Avatar
Finished up the firewall insulation and carpeted covering, which was all I needed to final install the floor carpet. I couldn’t resist throwing the seat in for a look. It will need to come back out to body work and paint the brackets, which I cut/welded 2” out of and sloppily spray-bombed a while ago. Interior is too nice now and they need to be pretty too
New pedal pads and trim, new stainless door sill plates, and a new shift boot and ring bring it all together, and I also took some 1200 grit to my shift knob to knock the sheen off. I’m not 100% sold on the stock style shift boot, but I’m not sure what I would do instead; leather and billet just don’t seem like they belong here...
-Chris
Old 05-09-2020, 07:24 PM   #2190
SCOTI
SCOTI's Avatar
It fits the theme: "Nothin' to see here folks"... then they start to notice little subtle details. It looks freaking great!
Don't worry though, someone knows someone that had one just like it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-09-2020, 07:24 PM   #2191
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks perfect.
Less is more and yours is super clean.
Most don’t realize the amount of work it takes to make things look stock.
Love the entire truck!
Keith
Convert to disc brakes.
Old 05-09-2020, 07:26 PM   #2192
darkhorse970
darkhorse970's Avatar
Very nice Chris!
darkhorse970 is offline   Reply With Quote
Old 05-09-2020, 08:17 PM   #2193
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Scoti, you get it!
Looks perfect.
Thanks Keith! Lots of effort taken to make it look like no effort was taken.
Originally Posted by darkhorse970 View Post
Very nice Chris!
Thanks Keith, maybe this thing might be on the road sometime soon-ish...
-Chris
Old 05-10-2020, 09:48 AM   #2194
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
Looking very nice, Chris. You need to get that thing finished up so that after all this Covid-19 mess is over we can get together for some talk and adult alcoholic beverages!
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 05-10-2020, 01:12 PM   #2195
gringoloco
A guy with a truck
gringoloco's Avatar
For sure brother, I’m ready for some cruisin’ and BSin’! Just a “short” list of things left to get her back on the road (subject to change/additions):
-Chris
Old 05-10-2020, 06:54 PM   #2196
nlped
nlped's Avatar
Oh My!!! That’s quite a list, man! But I have to admit, I wish I was that close in Walter.
Carter
Old 05-10-2020, 11:25 PM   #2197
kehstr
kehstr's Avatar
Looks Fantastic!!
I agree with the shifter boot. Not quite sure if it works or not.
Have you thought about something like this one from Jegs, and then dialing the shine on it back??
https://www.jegs.com/i/JEGS/555/62382/10002/-1
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 05-11-2020, 08:31 AM   #2198
gringoloco
A guy with a truck
gringoloco's Avatar
I know, the “end” felt closer before I wrote it down. Just keep chipping away, we’ll get there
Originally Posted by kehstr View Post
Looks Fantastic!!
Thanks! Though, I’ve never really been a huge fan of the Hurst-style boots. I think this one will get some stainless pan-heads and call it good for now. If it wears on me I’ll change it whenever I decide to do blue carpet
-Chris
Old 05-22-2020, 08:46 PM   #2199
gringoloco
A guy with a truck
gringoloco's Avatar
Getting the Hill’s Rod and Custom (now Stoner Speed Shop) inner fenders installed, and boy, lemme tell ya, what a pain. But, man do they complete the “stock, but not” theme in the engine bay. Still lots more to do to get everything fitting perfectly on this side before moving to the driver’s, which should go a little smoother now that I have some clue of how to attack it. Bonus: the billet hinges fit with plenty of room to spare
Undecided on the cut fender edge treatment, I’m tossing around leave as-is, weld in a rolled edge, or use press-on door edging...
-Chris
Old 05-22-2020, 11:58 PM   #2200
SCOTI
SCOTI's Avatar
Wow! I didn't realize aftermarket (fender mounted) hinges would clear the HR&C/SSS tubs. That's great to know. I didn't want to have to cut the cowl on my 67/68 RetroRod for PB's style hinge.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
