![]() Join Date: Jul 2001
72 Correct antenna with AM/FM versus AM
I would like to find the correct antenna for my 72. The truck originally had an AM radio, but someone has put an original AM/FM radio in it.
What antenna would came in a 72 with an AM radio? would it work with the AM/FM? What is correct for an AM/FM? Thanks, Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
Just like to part out trucks!!
Re: 72 Correct antenna with AM/FM versus AM
I am curious about this to Ray
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
![]() Join Date: Sep 2001
I believe (and that's all it is), all radio antennas were collapsible mast until some time in early 72 when the fixed mast were used.
If anyone have definitive information, I'd love to see it. Dan Posted via Mobile Device |
DND Trucks
![]() Join Date: Dec 1999
Not 100% sure, but I'll throw this out there anyway. Every truck that I've owned that had a factory am/fm in the truck and listed on the SPID, had a non adjustable mast.
#16876
None adjustable on all & same for AM & FM as far I know.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
FM operates with a solid mast,so probably the solid masts were used. I never had a 67/72 that didn't have a fixed mast. All the newer antennae have been fixed,since most vehicles had FM
FM requires a fixed length I believe it is 32 inches. A adjustable will work best if it is extended to 32 inches
69 Chevy 4x4 383 Power ![]() |
![]() Join Date: May 2010
I recall hearing this also back when AM/FM was new. The only thing that's a bit different is that I thought it was 31". So, somewhere around 31"-32" should give optinum reception. Just measure the length of a fixed mast and use that. I don't know what the original FM trucks came with. I've only seen adjustable masts on these trucks, but they all may have been AM radio equipped.
Yep,I meant to say "FM operates at a fixed length",when I said "...a solid mast". Same,but different. I always heard 31",but have measured some from different years and they vary slightly. I guess there's a little wiggle room,but telescoping masts are for AM or for those who want to lower for some reason,then readjust back to proper FM length. GM was smarter than most other companies and made parts that interchanged and used a mast that worked with either radio.
This is really informing to me. I understand now that the length for the FM to work properly had to be 31-32 inches.
So did the adjustable antenna only came on trucks with AM? Or was an year thing? I had originally thought each radio would of came with it own antenna. So I should be looking for a fixed mast antenna? Thanks, Ray Posted via Mobile Device
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White Last edited by 72 Super; 04-21-2013 at 09:28 AM. |
So it almost seems that all 72's came with the fixed mast antenna? Were adjustable ones for earlier years, AM or??
Thanks, Ray
![]() Join Date: Oct 2012
Does anyone have any additional comments or knowledge on the 'correct antenna' question,
discussed above, as it pertains to AM-FM radio reception ??
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
![]() Join Date: Jan 2001
One of my Army qualifications was 25D - communications, which includes wave theory. So here's the scoop. If you take the frequency range of commercial FM broadcasts, a 31 to 32 inch antenna will give you 1/4 wave of the average range, which is the best overall compromise. If you had a favorite radio station at a specific frequency, you could easily calculate the perfect 1/2 wave antenna for optimal signal, but it would be over 5 feet long.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Who Changed This?
![]() Join Date: Jan 2013
The mast is 1/4 wavelength because the other half of the dipole is a reflected image in the ground plane (not a very good one, since the fender isn't all that flat). AM radios had an adjustable mast in order to pick up the lower end of the frequency if you were way out in the middle of nowhere, far from the station. FM is 88 to 108 MHz. Rule of thumb is at 1 GHz is wavelength 1 foot, so 100 MHz wavelength would be 10 feet (10 times lower frequency). Divide by 4 for the 1/4-wavelength yields 2.5 feet, which is 30 inches. 31- 32 inches is a compromise due to the lower frequency end of the FM spectrum. I designed and built aircraft and spacecraft antennas for about 10 years. There are antennas now that are much shorter than 1/4 wavelength, but that's fractal stuff like you would find inside a cell phone.
#15 |
![]() Join Date: Oct 2013
Hello I have a 72 with am/fm and an adjustable antenna I thought was original.
#16 |
Who Changed This?
It probably is. I don't know when the change over was started or completed. But if you have AM or AM/FM, you might need to adjust it. Almost nobody had an FM only radio in those days. I did see FM only cassette players, though.
#17 |
Thanks, I always just extended it all the way but now I'll mark it, its too tall for the garage.
#18 | |
Who Changed This?
#19 |
1260 am k-surf
I started out with nothing - and I still have most of it |
#20 |
Who Changed This?
Well, there's a vote of ONE!
