grill question
Is this grill the same but just blacked out ? I like the blacked out one but want to make sure of the year.I have a 80,s truck with and old tube grill and will that model fit ?
Re: grill question
This may help.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
Re: grill question
forgot to mention my truck hood is cable release. Looks like a 77 grill is used on the black out grill
Re: grill question
77-79 The 80 is squares one yr style.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
