Parklight wire harness
I have a 72 Jimmy and the Parklight which is right below the double headlights in the front grill. I have not been able to find the harness that plugs into the light and the radiator support frame I have one but need two. 12 to 16 inches long, if I remember right it also is part of the turn signal.
Re: Parklight wire harness
Isn't the core support meeting place just a grommet and the harness is actually the whole front harness.
That runs from the cab to the battery... Try wiringhaness.com, then ebay once you have a part number. I actually have a complete new set of harnesses for a 72 Chevy that I paid a mint for. |
no the wire harness connects at the core support and to the parklight housing it is only about 12 to 16 inches long
Is it the same as the Chevy?
My 72 jimmy has the turnsignal and park lights are in the bumper, I should have two, since I changed my front end, if you need them let me know
[img]jpeg 050[/img]
This is what I am looking for |
The bulb socket is standard, but I can't see inside electrical side, probably two blades, but what configireation I don't know. One horizonal and one vertical.
Are you sure it's not a side marker light This is for a 67 turn signal ![]()
#8 | |
