Old member
I took the Ramp truck to the guy to start the front end swap. He is gonna pull the whole front end craddle and put the 86 model in it. He is also gonna replace the worn out motor mounts also while he has it. Got all the parts ordered and should have them all by Wedensday.
The only thing I'm not sure on is the pitman arm. If I need to use the one on it now are get one for a 86? Any thoughts on this. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
laying low
![]() Join Date: Mar 2001
Re: So it begin's
Does the truck have a late model power sector on it? If so I would use the right pitman arm for the application.
#3 | |
Old member
![]() Quote:
![]() Join Date: Jul 2015
Re: So it begin's
Don't throw anything out, if you have space store it. Either you or someone else will find value in it in the future of course.
Re: So it begin's
The other thing some parts may not be made anymore and you may need it to finish your truck
