Old 03-25-2020, 10:53 AM   #101
cebra
Re: '72 Cheyenne K10
Originally Posted by jimbosprint View Post
The distance between the seat back to the horn button is 21.5", and the distance from the seat back to the bottom of the steering wheel is 15.5".
Perfect, thanks.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 03-25-2020, 11:05 AM   #102
cornerstone
cornerstone's Avatar
Personally, I like the Warn bumper best, but the custom one you have designed is cool also. I think the only modification I would make is the size of the pipe. I'd want it a bit larger diameter. It'll look nice having a matching set.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-01-2020, 12:37 AM   #103
jimbosprint
jimbosprint's Avatar
I decided to swap the Edelbrock 1406 carb from my C20 onto this truck today. The Quadrajet on it (sitting over a decade) did not run well and was hard to start because the choke wasn't working right. I figured at least it would eliminate the carburetor as a problem. It starts easily and idles decent with the Edelbrock. I need to set the timing again and hook up the vacuum advance to see if it still has the backfire issue.
It felt good to wrench today and make progress. Sometimes it seems like I throw money and parts at this project and it still sits in the driveway and doesn't move. Today cost nothing and my truck runs better.
jimbosprint is offline   Reply With Quote
Old 04-01-2020, 07:17 PM   #104
jimbosprint
Checked the timing today, and it still backfires when you hook up the vacuum advance. I think there is something wrong with the distributor. Timing is 12 at idle (750rpm), but the timing goes wild when you give it any gas and it backfires out of the exhaust.
I ordered an Edelbrock 1906 carburetor today too. I just have to decide which truck will get which carb.
Old 04-05-2020, 10:33 AM   #105
jimbosprint
Nothing better to do during this stay-at-home pandemic, so I rebuilt the Quadrajet that was on this thing. I was surprised to find that it was actually pretty clean inside. I think it was rebuilt before at some point. Should I throw this on there and see how it runs? I'll probably just go with the 1906 that I ordered and save this in a box.
I'm fairly certain that the cheap Speedmaster distributor that I bought from Jegs is junk, and is the cause of the timing problems. I ordered a Summit Blueprint HEI, which is the same part that my C20 has.
Old 04-08-2020, 07:28 PM   #106
jimbosprint
So I couldn't get the Quadrajet to start. Oh well, not like I was expecting greatness from my rebuild. I installed the new Summit HEI and Edelbrock 1906, and it was running smooth in no time. What a difference!
Today's lesson: Do not buy a Speedmaster distributor no matter how cheap it is.
Link to video: https://youtu.be/dexU3mqCg50
Old 04-11-2020, 01:30 PM   #107
jimbosprint
Sent in registration paperwork today. I hope to have this truck on the road soon!
Old 04-11-2020, 01:44 PM   #108
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I hope DMV hurries up.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-15-2020, 04:03 PM   #109
jimbosprint
Old and moldy got a bath today!
Old 04-16-2020, 07:46 PM   #110
jimbosprint
Lumber rack and tool box are back on.
Old 04-27-2020, 01:46 PM   #111
jimbosprint
A friend gave me this grill. It looks way better even with the outer grill all bent up. Now I need a .
Old 04-27-2020, 02:34 PM   #112
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I love this truck. Would love to find one like this, but in MO it would have so much rust it wouldn't be worth it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-27-2020, 05:43 PM   #113
jimbosprint
Thanks! Keep looking. They are still out there hiding just like this one was.
Old 05-03-2020, 09:06 PM   #114
jimbosprint
If you ask your Chevy truck friends if they have a grille for your 4x4 project and you end up with all this, then you have good Chevy truck friends. The extra parts I don't use will go to someone that needs them. Parts karma. Thanks John and Nathan!
Old 05-04-2020, 08:57 AM   #115
Ol Blue K20
Looks great, such nice guys to help ya out.
Dale
Old 05-04-2020, 05:48 PM   #116
jimbosprint
Switched out the grille today for the broken one and one of the better outers. The inner needed a little super glue, but it suits this truck better than the nice one.
Old 05-04-2020, 08:38 PM   #117
rustytruck50
rustytruck50's Avatar
Looks great! I need a driver grille shell & bowtie for mine....
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 05-05-2020, 07:46 PM   #118
jimbosprint
Plates and tags! Super excited now that this truck has current licensing and insurance. I need some bumpers!
Old 05-05-2020, 09:27 PM   #119
Ol Blue K20
congratulations on the tags and plates. I would be tempted to drive it without bumpers....lol
Dale
Old 05-06-2020, 11:33 AM   #120
jimbosprint
Thanks. I just might have to drive it (a little).
Old 05-06-2020, 01:56 PM   #121
jimbosprint
First trip to the gas station.
Old 05-06-2020, 03:33 PM   #122
Ol Blue K20
Yaaaahhhh!!....congrats on it's maiden voyage.
Dale
Old 05-06-2020, 04:06 PM   #123
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Cheers. May it be the first of many.
Old 05-06-2020, 11:18 PM   #124
cornerstone
You've made just the right fixes and repairs to this truck. Hats off to a job well done! Enjoy it!
Brian
Old 05-07-2020, 12:11 AM   #125
jimbosprint
Thanks guys. I still have a few things on my list to fix before I can really enjoy it.
- I wired up some turn signals today.
- Previous owner told me that the front and rear differential gears don't match. I need to figure out what gears are in it and the condition and have repaired. Can't test the 4wd until then.
- Needs an alignment since all the steering was replaced.
- Brakes work, but not great. I still need to put new pads on the front, but I just might pay a shop if that doesn't make them better.
- The truck needs bumpers. The two local quotes I got for custom bumpers were around $2500, which is more than I wanted to spend. I want to use the winch I have. I'm worried my ideas are bigger than my wallet.
- Backup lights don't work. I need to check neutral safety switch and wiring.
- Temp gauge is pegged hot since I replaced the sensor. I need to figure out why.
- I want Vintage Air, but that will have to wait until all the other mechanical issues are solved.
ochre
