05-05-2020, 12:44 PM | #1 |
Windshield washer pump replacement
What is easiest way to remove and replace the washer pump?
05-05-2020, 01:17 PM | #2 |
Re: Windshield washer pump replacement
Remove the bagel cluster. May have to drop the column to do so. I will seem like more work at first but you will be glad you did.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
05-05-2020, 02:20 PM | #3 |
I am guessing "gage cluster" is what was referred to here. I must admit, I read it twice and was trying to figure out where my bagel cluster was located.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
05-05-2020, 03:58 PM | #4 |
Or go for an aftermarket one like this:
05-05-2020, 09:16 PM | #5 |
You would be correct.. dang auto correct.
05-05-2020, 09:22 PM | #6 |
05-06-2020, 12:18 PM | #7 |
Even if you use the boneyard arrangement from a later model GM, you will still need to tie in the wiring to the factory pump wiring. Meaning, you still need to pull the gauge cluster to easily access.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
05-06-2020, 12:22 PM | #8 |
I want a Bagel cluster!
Are you wanting to replace factory with factory? Or do an upgrade?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-06-2020, 01:27 PM | #9 |
I did jobber one in my 68 years back then put a factory style one in after they started to be reproduced and now looking at possibly upgrading my 72 with a newer style either 91 or 2003 depending which fits better and which can carry more washer fluid
05-06-2020, 06:40 PM | #10 |
Why are you replacing it?
If it’s not pumping, have you tried “Force Priming” it? Take a squeeze bottle and hook it to the hose from the reservoir. While you siezest the bottle, press the washer/wiper switch. After a few seconds, If the pump is good, it will start to squirt on to the windshield. If the diaphragm is bad it won’t. The easiest was then is to put a remote pump in, and there’s several threads on what type to use and how to do it. If you’re going for the “Original equipment” route, then you’re about to embark on one of the more tenuous/difficult tasks associated with these trucks. Good luck |
05-06-2020, 08:29 PM | #11 |
one of the first things I did was replace the factory pump with a factory replacement 2 years it went bad . dont waste your time or money go with a more modern setup
05-07-2020, 10:22 AM | #12 |
Totally agree with this statement. If the pump was easier to access then it would be no big deal to deal with, but it's about the most buried thing to get to under the dash, especially with AC. Doing a simple rewire and sticking the pump under the hood makes things much easier to fix any problems. I know some like the original squirt-squirt-squirt of the old style pumps, but that's not important to me.
