Old 05-06-2020, 09:51 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
3 Spd Manual Trans. Speedo cable "bullet"
Guys, Anyone know where i can source a speedo cable insert for my 3 speed Column manual on my 71 C10? I tried a couple of transmission shops and cant find one. I am going to have to replace my clutch at some point this fall once my son starts driving the truck alone and I am picking up gaskets for the transmission, rear main and oil pan .... going to see if I can get it a little less gooey down there while I am at it. The speedo cable is leaking and best I can tell from searches here its not as easy as a single O ring, there is a part that is wore out inside that chamber. Looking for that part.
thanks in advance
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 05-06-2020, 09:54 AM   #2
MJN
MJN's Avatar
Re: 3 Spd Manual Trans. Speedo cable "bullet"
Give these guys a try if you haven't already
https://transmissioncenter.net/?prod...edometer-gears
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-06-2020, 10:01 AM   #3
phlegm
phlegm's Avatar
Thanks! Will do
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 05-06-2020, 10:48 AM   #4
geezer#99
geezer#99's Avatar
Those guys are good to call.
Make sure you get an internal o-ring too. The bullet sometimes doesn’t come with it.
Another thing. Your speedo gear might be worn on the shaft and you’ll need a new gear too.
geezer#99 is online now   Reply With Quote
Old 05-06-2020, 12:58 PM   #5
phlegm
phlegm's Avatar
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 05-07-2020, 11:38 PM   #6
CarlsLQ9SS
CarlsLQ9SS's Avatar
I have one from my old 3 speed transmission. I sold the transmission but pulled the bullet a year before I sold it and just ran across it in my garage.
CarlsLQ9SS is offline   Reply With Quote
