![]() Join Date: Aug 2018
Volt gauge conversion from a 1980 trans am
I done a conversion with a trans am volt gauge with the choke window in it. I got an engine light from a Ford F-150 and used it in the window instead of the choke because I’m doing a Ls swap on my project. What do you all think?
The Older Generation
Re: Volt gauge conversion from a 1980 trans am
Looks good. LockDoc
Thanks, I already done the s-10 speedo conversion but havent painted the lens for 120mph yet. I am working on a 7k tach for it and waiting on the stencil so I can paint it all at once. I have an air pressure gauge cluster also and thinking about using the tin to do a trans temp gauge in its place.
![]() Join Date: Jan 2017
I like it! If you do the trans temp please post up some pics.
Will do! I have a buddy working on stencils to paint the lens for the tach conversion im doing and he is making one for trans also. just have to find a gauge that will work in the bezel and still look factory.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I like it, looks good
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
All about them K’s
![]() Join Date: Jun 2014
That’s pretty cool. That’s a good idea on the engine light.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Cluster King
Very nice for the LS guys.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Dec 2013
What year trans am for volt gauge?
Cluster King
This came from a 1980 but I would think any F body around that year will work. It was an easy swap also, all i had to do was drill one hole to get the gauge to mount and then i drilled one for the light for the check engine. didnt have to move the factory holes either and it lined up perfect. Thanks for the compliments guys. Its still a work in progress.
I have a 1980 pace car and it has the same gauge also.
Here is some more pics of the conversion
Here is some pics of the tach conversion I will be doing, I am using a tach from a Jeep and gonna use the factory reproduction tach face and try to use the needle. Tbone informed me the factory needle doesn’t come off the factory tach so unsure what I going to do there as of yet but hopefully I can figure something out because I want it to look as factory as possible. I know the computer for the Ls swap can be programmed to put a 8 cylinder signal but I wanted a higher rpm tach. I will post more pics as I get further into the conversion.
#15 |
CarlsLQ9SS Question if you don't mind. How did the window light up when it was in the Trans Am?
Like your idea. |
#16 |
Cluster King
#17 |
#18 |
It originally lit up as a choke light. I just changed the lens to the ENGINE lens and drilled a hole in the tin for the light from the harness for check engine.
#19 |
Here is some updates on my gauges. I replaced the bezel and added a trans temp gauge. Also found a 8k tach lens on Ebay for my build. I took an old sun tach that I've had for years that has the same sweep as the lens and I bought and used an aftermarket 67-72 tach and merged them both together to make it look original. So it has a setting on the back for 4cyl, 6cyl and 8 cyl and I tried it on an old small block and it works good. I am now waiting on my tins to get back from Les so I can finish it up. I also done the s10 speedo swap on it for my ls swap. Here is a few pics of my progress.
#20 |
Here is my tach
#21 |
![]() Join Date: Jul 2008
Nice work! What vehicle did the engine light come off? And what are you using for the dash light sockets?
1965 c/10 swb 1969 c/10 lwb ![]() |
#22 |
The engine light came from a 96 f-150, and the bulb sockets are from the parklight bulbs from a 2001 silverado
