Old 01-29-2020, 02:27 PM   #1
HeavyHauler
What ball joints for the ECE 2.5 drop spindle for 1968 Chevy C10?
I purchased a complete 5x5 front disc brake conversion kit from ECE and it included the 2.5 drop spindles for my 1968 Chevy C10.
I forgot which ball joints the spindle will need?
I tried calling ECE but have not received a call back as I also wanted to purchase some parts while they are having a sale.
HeavyHauler is offline   Reply With Quote
Old 01-29-2020, 02:48 PM   #2
396ci
396ci's Avatar
Re: What ball joints for the ECE 2.5 drop spindle for 1968 Chevy C10?
i got the same kit for my 1970 and it uses the stock ball joints (for the drum spindle). they taper the new spindle to match the old ball joints.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 01-29-2020, 03:27 PM   #3
Southcity
Southcity's Avatar
As an fyi, ECE has closed it's doors recently. Sad news for sure as they were a go-to resource for parts and tech info for just about all of us here on this board. But this is most likely why it will be difficult to get a response from them if at all.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 01-29-2020, 04:10 PM   #4
HeavyHauler
So I should just be able to go to Autozone or Oreillys and get upper an lower ball joints for a 1968 Chevy C10?
Old 01-29-2020, 04:41 PM   #5
Southcity
Southcity's Avatar
I highly recommend Moog (problem solver) for your ball joints or any suspension replacement parts.
Old 01-31-2020, 06:53 PM   #6
3767
Yes u can go to your local parts store and get what u need. Moog problem solver is 1 of the better ones made. The upper bolts n so u should get new hardware with the ball joint. U can also order online thru rock auto. Get some grease for ur gun while u are there. Dont make 2 trips if u dont have 2.Let us know how it turns out.
3767 is offline   Reply With Quote
Old 02-01-2020, 11:16 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bummer. I just recently installed their drop spindles and leaf springs.
I used Moog suspension & steering linkage.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-02-2020, 10:01 AM   #8
Grumpy old man
Grumpy old man's Avatar
I replaced all of my front suspension with Moog from Rockauto on my 67 and wrote all the part #'s down in my build book if anyone wants them .
I made a "build book" to keep track of all the upgraded parts and pieces ,it has the part #'s ,Where I bought them , and when so I have an easy reference if anything needs to be replaced down the road . or for use by the next owner .
Old 05-09-2020, 06:27 PM   #9
cst350
cst350's Avatar
GOM, I am curios which upper ball joints you used. I am trying to install some Hotchkis upper a-arms with proforged 101-10037 and they simply don't fit. The MOOG equivalent is the K6024. My truck is a 69 that I converted to ECE discs many years ago. Thought I saved the receipt but of course I can find everything but the spindle info...
cst350 is offline   Reply With Quote
