Old 05-11-2020, 07:50 PM   #6
C130Nav
Re: 72 ABS brake lines
What are you doing for a gas tank? Since the original Av tank will be too long once the frame is shortened, I was thinking either using the SWB Tahoe tank, or ditching the spare tire assy and using a late 80s FI 'burb tank behind the rear axle. Also, I think I'll need to relocate the upper rear shock mounts down below the top of the frame over the rear axle. That will allow me to get the rear of the burb body closer to the frame in the back. The rear rise measurements I've taken on both the 2WD burb frame and the 4WD Av frame shows the Av having about a 2" higher rise over the rear axle.
Are you fabbing up body mounts yet?
C130Nav is offline   Reply With Quote
abs, brake system, frame swap, suburban 4x4
