05-14-2020, 07:36 PM | #26 |
Re: 53 3100, s-10, ls, tr6060
Squared off the front rails, boxed them off and added a crossmember. Painted all the new brackets and threw the cab back on. Cut the transmission cover for the tranny as well.
53 GMC COE stock 53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949 '70 Chevy C10 LWB 350/sm465 74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
05-14-2020, 08:27 PM | #27 |
are you gonna use a shifter relocater for the tr6060?
05-14-2020, 09:57 PM | #28 |
Going to use a core shifter. Puts it right on top where the blue tape is. One of the things I have to have is a bench seat so I have no other options.
And for info, that’s the 5th gen trans. The cts-v trans won’t work with a forward shifter.
53 GMC COE stock 53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949 '70 Chevy C10 LWB 350/sm465 74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags Last edited by layinrocker65; 05-14-2020 at 10:35 PM. |
05-14-2020, 10:57 PM | #29 |
looking good, I used a core shifter on my 65, we had some fun back and forth on why I needed a short shifter and 16" hurst bench seat shifter for an NV1500 (4 cyl s10) trans. "I can build it but I think its going to hit your dash". "Its not going to hit my dash". high quality stuff!
probably the right move, raising the truck a half inch! motor looks right
05-14-2020, 11:44 PM | #30 |
Thanks joedoh. Seems to be working out really good. Im going to run ~27.5 tire so Ill have plenty of options to go lower with suspension mods if I want.
I put the bench back in the truck and sat in it for the first time. I dont know why but the I feel much closer to the dash than my COE. Its not even close to being comfortable for me(Im 66). So Ill be trying to find a new bench seat to swap in and try to gain a couple of inches. If I can go back 2-3 and maybe down a bit, Id be happy.
05-14-2020, 11:54 PM | #31 |
I used a 3rd row bench out of an Astro van. Moved me back about 2.5". and I dropped it 1" ( im 6'3) I have plenty of leg room and the 4 spd shifter falls right into place.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
05-15-2020, 12:43 AM | #32 |
yeah with the stock bench you are really steering with your gut, keeps your hands free for sandwiches I guess.
05-15-2020, 12:56 AM | #33 |
my LS3/TR6060 came from a 2013 Camaro...ive got several forward mounted shifters ive looked at saved on a computer at home..just not sure which I like best....some are very pricey
05-15-2020, 01:05 AM | #34 |
The core one is the only one I could find where you can get a tall mount to run a long handle on it.
05-15-2020, 08:57 PM | #35 |
Getting the bed and steps mocked up. Once I figure out there positioning, Ill start making mounts. I got the core support cut and welded a new bottom to it. Need to figure out how I want to mount it now.
05-17-2020, 07:31 PM | #36 |
looks just right!
05-18-2020, 06:38 PM | #37 |
Got the motor mounts knocked out today and notched the frame for a low mount drivers side alternator. Pretty sure Im done cutting both the inner fenders but no pics of that. I feel spoiled with how much room there is to work around these trucks.
Still havent figured out the pictures. Im always forgetting to take them in landscape
06-19-2020, 11:00 AM | #38 |
06-19-2020, 06:58 PM | #39 |
Thanks!
06-19-2020, 07:02 PM | #40 |
Been a while since I updated this. Went from having all kinds of time off for the Rona to all my days off being cancelled. Got the boards mounted up. Still need to brace the mounts when the cab comes off again. Mounted the front bumper and the throttle pedal.
53 GMC COE stock 53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949 '70 Chevy C10 LWB 350/sm465 74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags Last edited by layinrocker65; 06-19-2020 at 07:18 PM. |
06-19-2020, 07:09 PM | #41 |
I started mocking up the frame mounted hydroboost and hydraulic clutch setup. I tigd a offset -6 fitting to the high pressure side of the power steering pump, mounted a f-body alternator in the low position and ran the steering shaft.
Sorry about the sideways pics
06-19-2020, 07:11 PM | #42 |
I also mocked up the 20s off my 74 to see how the truck is going to sit. The front is perfect to me here. The rear needs to come down a little I think.
06-20-2020, 10:55 PM | #43 |
looking good man!
06-20-2020, 11:08 PM | #44 |
I like it..!!!! just as is
08-09-2020, 02:06 PM | #46 |
Guess I’ll update this. Got the steering done with a shortened stock steering column. Made the pedal assembly and got it mounted. It’s a hydroboost and Wilwood clutch master mounted under the frame on a custom mount setup I did. It all bolts on with 3 bolts were the original tranny crossmember was and 4 bolts to the side of the body mount.
Got the tank mounted. It’s a blazer tank. The fill will be in the bed floor. As always, sorry about the pics. Don’t know how to rotate them on my phone.
08-09-2020, 02:27 PM | #47 |
Got the brakes pretty close to done. 2 drop spindles, S10 rotors machined into hubs, CTS-V 6 piston brakes with the 2 piece rotors opened up in the center.
08-09-2020, 02:30 PM | #48 |
I am opting to use the TR6060 from the LSA setup to save some money. Because of that, I had to make my own remote mount shift since the aftermarket doesnt support the Cadillac TR6060. The linkage is just mock up until I can determine the height of the shifter in the truck. Then Ill make a new linkage and shift handle.
08-09-2020, 02:35 PM | #49 |
Made a subframe to stiffen things up. 1.75 tubing with a knock out tranny crossmember. The exhaust will be able to run under the subframe and be above the bottom of the floorboards.
