Radiator
Does anyone make a radiator for a v8 in a 48 gmc truck?
Re: Radiator
Looks like Champion makes a three-row and a four-row:
https://www.championradiators.com/GM...ator-1947-1954 |
Re: Radiator
Stock-style radiators have plenty of reserve cooling power for a V8.
Re: Radiator
I ran a big truck radiator in my 48 3100 that the radiator shop put a bigger upper neck on for years until the core gave out. Old cores are old cores and finding one that is in good enough to use is a challenge now that they are over 65 years old.
OOPS, THIS ISN'T GOING TO WORK IN A GMC WITH A GMC CORE SUPPORT. You need a radiator with the filler neck curving into the back side. Brice Thomas will custom make a US made radiator but they aren't cheap https://cgj.com/ Looking at the champion that Chopped53 posted that may be your best option. I did put an inquire into Engineered cooling products to see if they can do one for a GMC. I have one for my truck from Engineered cooling products This one http://www.speedcooling.com/1948-195...-Radiator.html I had it out of the box yesterday to take some photos to show someone on another board what the companies's work looks like. Painted black it would look like a stock radiator outside of the tig welding if that was the look you wanted rather than the aluminum.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 05-18-2020 at 12:51 PM. |
Re: Radiator
Thanks for all the info.
Re: Radiator
This is a USRadiator for a GMC truck. This one was configured for hose sizes and locations for an LS V8. Has provisions for a steam port hose too. This one has a fiberglass shroud and a big SPAL fan installed
Here's the other side with the condenser and drier installed. |
Re: Radiator
Oh, and if you plan on using the Vintage Air kit for the AD truck on a GMC, it won't fit.
You'll have to remake all the mounting brackets for the GMC - it only fits the Chevy |
Re: Radiator
Is that the condenser mount brackets? As he has a V8 he just needs compressor mount brackets for that particular V8 and six cylinder brackets aren't an issue. The inside unit should mount the same.
Re: Radiator
Yes, I was speaking in the context of the condenser brackets that Vintage Air says fits the Chevy and the GMC, but in fact the condenser-drier kit will only fit the Chevy. The brackets in the picture had to be remade to get it to fit my GMC
Re: Radiator
Thank you
