Old 04-20-2020, 10:35 AM   #176
cornerstone
cornerstone's Avatar
Re: Uncle Loyd's 72' C-10
Originally Posted by TA_C10 View Post
I know what you mean hurting for a couple days. My neighbor and I just pulled 2 twelve hour shifts building a fence this weekend. I won't be worth much this week. And for the drain I went with the center location. That drain line isn't ideal but in the center the passenger feet will typically straddle it for the most part. I have that drop the instructions called for too. I drilled a hole in floorboard so I could squeeze the 90 degree fitting attached to hose and it be super snug. No sealer.
Thanks. That's where most of the guys place it based on the photos I see out there. I'll move mine to the center also and just plug the hole I jabbed it in... I guess the carpet lays over the port?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-20-2020, 11:02 AM   #177
TA_C10
TA_C10's Avatar
Yeah I just cut a slit in my carpet and it went around the hose no problem.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 04-20-2020, 11:10 AM   #178
cornerstone
I want to figure out a way to keep my firewall smooth. The VA evaporator needs to be bolted to the inside of the firewall. If I weld a couple studs to hang the thing I doubt I'll have enough room to reinstall it. Has anyone found a better solution besides this idea?
Brian
Old 04-20-2020, 11:20 AM   #179
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I put my drain hole more to where you have Option 2, but I put mine as high up but still under that cab support. The hose will run down inside that to below the inner fender. I would post a pic, but I don't have the truck.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-20-2020, 04:09 PM   #180
sprint_9
sprint_9's Avatar
I'll see if I can get you a picture of mine. I ran it out the side of the cab, I thought it worked out pretty slick.
Ok here are some pictures of mine. I drilled a hole out under the cowl vent. I used the stock Vintage air drain hose to get it out that far, then I bought a 90 degree fitting and ran some clear hose down out between the cab and the fender. I used a grommet and got a nice press fit so everything is sealed good, I also used clamps on everything so it wont fall apart with time or leak. I haven't used it yet but everything has fall so it should work fine.
sprint_9 is offline   Reply With Quote
Old 04-20-2020, 04:25 PM   #181
1971Stepside
Almost Satisfied
I welded the studs in on my firewall on the inside. I have plenty of room to bolt them up. It is fun getting the hoses connected on the inside though.
Old 04-23-2020, 09:20 AM   #182
cornerstone
Thanks for the pictures Sprint, I believe I like your design the best!
Brian
Old 04-23-2020, 09:27 AM   #183
cornerstone
I started messing with my doors. I noticed on the inside, I have surface rust that I’d like to get rid of before I try to paint this truck. My first inclination is to use my new small blaster, assuming I can fit it in the access holes and reach the problem areas. Any other ideas?
Brian
Old 04-23-2020, 09:56 AM   #184
MDPotter
MDPotter's Avatar
Those spots are hard to get to. If you try to blast them, the sand/air is going to blow back at you and it'll be an unpleasant task. I pulled the skins off my truck, had the shell blasted, then epoxied them but if you don't need to replace the skins then I would try getting in there with a red scotchbrite and/or a wire brush to take off the loose rust and then use a rattle can rust encapsulator like Eastwood.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 04-23-2020, 10:52 AM   #185
cornerstone
Yeah, not a fun job for sure. I’ll look into the differences between the red scotchbrite and the green, I’m guessing the red is more coarse? I’ve heard so many mixed reviews about rust encapsulators, but I think the majority of problems are from painting over it. The only thing I will do is add sound deadener inside the doors. Thanks man.
Brian
Old 04-23-2020, 10:58 AM   #186
1971Stepside
Almost Satisfied
I scuffed as much off with 80 grit as I could and then sealed the inside up with POR15. My body shop recommended that. I will put dyno mat over the POR at some point. My drivers door is a newbie so I just left it as is.
Old 04-23-2020, 11:03 AM   #187
MDPotter
MDPotter's Avatar
Green is about 600 grit whereas red is about 320. I use mostly red, it's a good all-around pad. But yes, topcoating over rust encapsulators is a bad idea. When the encapsulator is the only coating, it's okay. We used it on my dad's doors for the same purpose as what you're looking for and it worked fine.
POR15 and Chassis Saver products work fine too, they are designed to go over rust.
Old 04-23-2020, 04:09 PM   #188
Racer2172
Nice work so far definitely a lot of good info on here you are killing it with this build.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 04-23-2020, 11:25 PM   #189
cornerstone
Thanks!... but I'd say "killing it" is a bit of a stretch!
Brian
Old 04-23-2020, 11:29 PM   #190
cornerstone
Is there an advantage in using a red scotchbrite pad over 320 grit sandpaper since they are basically the same grit?
Brian
Old 04-24-2020, 09:24 AM   #191
MDPotter
MDPotter's Avatar
I like to use scrotchbrite when hard to reach areas are involved because the fibers reach much better than sandpaper. I also use it over EDP when I'm getting ready to spray epoxy over it. It's also my experience that 320 loads up pretty quick and wears out fast. I can't remember the last time I used 320, it's in an area of the grit spectrum that I don't use. The highest I go with dry sandpaper is 220 when I'm blocking. Then I jump to 600 wet for final sanding before sealer or base. When I say "jump", I mean I don't use any grits between 220 and 600, not that I go straight from 220 to 600 when sanding. I've never been good at getting all of the sand scratches out when going through the blocking steps and ending with 600, I always miss scratches. So once I'm done blocking with 220, I spray another coat or two so that I have a fresh coating to final sand with 600 so I know I won't have scratches coming through. Probably more info than you wanted.
Old 04-24-2020, 10:59 AM   #192
cornerstone
Not a chance of that happening! Between you and Randy500 I may learn how to do something I've always wanted to do. Many thanks for any and all tips or comments.
I'm now on the hunt for red scotchbrite.
Brian
Old 04-24-2020, 11:11 AM   #193
MDPotter
MDPotter's Avatar
If you ever want more info on bodywork, let me know. I'm by no means an expert, but I've learned a lot of what not to do. It's not scary, it just takes time to learn and a little money to get some good tools and equipment.
You should be able to get scotchbrite at your local auto paint shop or AutoZone, Napa, etc. If you're not in a hurry, Amazon.
Old 04-24-2020, 08:20 PM   #194
cornerstone
I bought my paint today. I’ve hemmed and hawed between base coat clear coat and single stage and even between colors for, well... years. I chose single stage primarily because I think the finish is more indicative to a classic. I really like the satins and the flats but I thought it would be best to try and do a stock looking paint job. Plus, if I screw something up I can just do the faux-tina look and I’d probably be happy with that as well.
Here’s what I got:
Nason brand single stage “Full-Thane 2k”
6 quarts of 510 “medium blue” (1.5 gallons)
2 quarts of 521 “linen white” (.5 gallons)
Reducer and slow activator
2 extra gallon cans with lids
Mixing cups
Paint stirring sticks and strainers
I also picked up an aerosol can of rust encapsulator for the inside of my doors to keep the surface rust at bay.
The total with sales tax and some state fees was 603. Seems like a good deal to me.
Brian
Old 04-24-2020, 08:57 PM   #195
sfont66
sfont66's Avatar
I may be a little late here, and I am a bit old school in my approach, but I like to use a pressure sandblaster. It is messy and should be done outside if possible.
The drawbacks,( other than the mess) is , they require a lot of air volume. I have a 6.5hp dual stage compressor with an 80 gallon tank and 60 gallon auxiliary tank.
That said ,they do a great job of cleaning up rusty parts. If you ever consider one for the future, the blast media you choose makes a difference. I tend to use silica sand or diamond grit( please use a respirator when blasting), choose one that has a choke valve in the air line, this will help to clear a clogged hose when the sand / air has too much moisture. Also get a few different sizes of nozzles, sometimes the smaller grit isn’t screened well and can clog the blast nozzle.
I have had several over the years, I had a nice one, but a friend borrowed it and never returned it. He took off with it and my ex wife, 30 years ago, good riddance ....my latest one is a cheapie that I had to modify,adding better pipe and the choke valve . I have pics, but don’t want to overstep.
Sorry for the rambling, it’s Friday and I’ve had a couple
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, FAST 102/102, FIC injectors,BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 04-24-2020, 11:40 PM   #196
cornerstone
I saw this home made blaster in the paint and bodywork FAQ threads... it sure looks like it'd do the trick. I picked up one of those small gravity feed blasters a couple weeks ago and it worked really good, so I will probably use it inside my door shells and spray the rust encapsulator into the corners or anywhere the blaster can't reach.
Your makin' me want to go to the fridge and grab a cold Billy Jenkins Bock. my latest favorite frothy beverage.
Brian
Old 04-27-2020, 09:38 AM   #197
MDPotter
MDPotter's Avatar
$600 isn't bad at all and Nason seems to be good stuff.
Are you doing the two-tone like the bed?
Old 04-27-2020, 10:20 AM   #198
cornerstone
That’s the plan, yes.
Brian
Old 05-19-2020, 10:27 AM   #199
MDPotter
MDPotter's Avatar
Any updates? It looks like you have all your paint, have you been bodyworking?
Old 05-19-2020, 10:38 AM   #200
MDPotter
MDPotter's Avatar
Have you figured out your fan wiring yet? I've been doing research on Gen V's in hopes of doing one on the next project. From what I've read, the ECM is not capable of turning on fans with a high/low function like the previous generations. It controls the speed of the fans in a variable speed fashion. That or you can install a temp sender and a standalone fan controller, but I like how clean the factory setup is and letting the ECM control the fans.
