Re: 69 shortbed emergency brake cable routing
Thank you Jim!
Does the e-brake line go between the inner fender and the two brake lines going up to the master cylinder? Or around the brake lines?
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
![]() Join Date: May 2010
It's rearward of the brake lines. You can also see that in the second pic of my previous post. The cable goes rearward behind the top shock mount. The brake lines run down the frame in front of the shock mount.
Jim Last edited by FirstOwner69; 05-19-2020 at 11:22 PM. |
