Re: ECE drop spindle disc conversion instructions? 67 C10
The rubber seal actually goes under the dust shield (between the spindle hub base & dust shield)
#2 | ||
Can anyone tell what the "clip" on the inner pad is for? and what it's orientation should be? As I have them set now, this clip is at the top of the spindle. If I swap the inner pads from left to right, it is at the bottom of the caliper. ![]() ![]() |
That's likely not a clip, but the pad wear indicator. When the pad is worn down it will screech on the rotor announcing it's repair time. It should be on the trailing end of the pad when the wheel is going forward.
#4 | |
![]() ![]() Join Date: Feb 2009
Looking forward to seeing what you do with your caliper fit. Hopefully I don't have a do-over (yikes). I was on the shy side about filing because everything is already finished. and word was it they work as intended regardless. Don't quote me on that, from here I'm a novice. Second instance I finish coated something only to find cast replacement parts aren't replacement parts until you break out a file, whoops! Water pump really (*()^ me off too ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-21-2020 at 10:01 PM. |
#5 | ||
