Old 05-20-2020, 01:39 PM   #1
SCOTI
SCOTI's Avatar
Re: ECE drop spindle disc conversion instructions? 67 C10
Originally Posted by 71CHEVYSHORTBED402 View Post
You happen to notice the calipers don't fit as nice on the spindle as original? My 71 wasn't quite flush like before. I did a little sanding since this pic, but it's still not a perfect fit like original.
That's a common issue w/aftermarket spindles so not any one specific brand. A little filing does the trick.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2020, 05:29 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I see. I only sanded a little off, perhaps I should have taken more, because they're not flush. It's my understanding that's for aesthetics only, so long as the caliper bolts insert as intended and the discs are square. Or so I hope
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
