Old 05-21-2020, 10:38 AM   #11
SCOTI
SCOTI's Avatar
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Originally Posted by 88Stanger View Post
Ok, so i believe i found a set of long tubes that are ceramic coated. They have 1.5" primary's and 3" Collector.
You want the most out of the motor? You need the headers sized accordingly (within reason). A 383 w/any decent cam & heads can move some air. 1.5" primary tubes will work but a 1 5/8 primary is better suited.
Beyond that, 2.5" true duals w/a H-pipe or X- crossover would be a decent set-up. Summit has a aluminized universal kit as well as a SS version.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
