#51 |
Re: 72 Plaid Sub
OK, So the way I purchased the 6.2L Engine, it was a short block with rotating assembly and heads. so there was no way of knowing if it was a truck or Car Engine. (it does not appear to have ever had a Vacuum pump mounted to the block so it was possibly a Camaro engine)
There was not balancer or water pump on the front of the engine. Currently it has a truck balancer and the Holley accessory drive system on it, as that is what was available at the time I started fitting the engine to the truck. I have talked Zach At drive junkies and know I will need to change to a Camaro water pump and balancer. |
#52 |
Re: 72 Plaid Sub
Ok, back at it where I left off. The was late 2017. Pulled the body off and installed some plumbing and wiring.
#53 |
Re: 72 Plaid Sub
Had to her put back together for Dino's Chevy Only Gitdown 2017. Here she is almost ready, just missing some glass and interior.
#54 |
Re: 72 Plaid Sub
Here's some pics from the Gitdown, the hotel, and Goodguys Southwest 2017. My brothers 66 Chevy next to the suburban was our grandfathers truck. It had been about 30 years since I rode in that truck. Such a cool weekend.
#55 |
Re: 72 Plaid Sub
Back home putting a few miles on the burb working out the bugs.
#56 |
Re: 72 Plaid Sub
In early 2018 I decided the burb needed to be a full blown show vehicle.
#57 |
The Older Generation
Re: 72 Plaid Sub
Lookin' good. I would have a hard time pulling it back apart if it looked that good and I was driving it..... ![]() LockDoc
#58 |
![]() Join Date: Mar 2007
Re: 72 Plaid Sub
Funny after having a full blown show paint job I'm going the other way, with my suburban build. We always want what we don't have right....What colors you have in mind?
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#59 |
Re: 72 Plaid Sub
Do you have any pictures of the interior? Where you able to get a 3rd row seat back there?
#60 | |
Re: 72 Plaid Sub
This is pretty cool too... https://www.instagram.com/p/BxK8rLHFNf0/
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#61 |
Re: 72 Plaid Sub
Wow, tail gunner seats! I hadn't even considered that. Very cool, love the truck.
#62 |
Re: 72 Plaid Sub
Thanks LockDoc. If the paint was original I would have left it. It was a repaint about 20 years ago and I just wanted it to look better.
#63 |
Re: 72 Plaid Sub
Going back with the same blue and white, but looking for a nice metallic blue now.
#64 | |
Re: 72 Plaid Sub
#65 |
Re: 72 Plaid Sub
Doing some rust repair. Drivers side was shot, but the passenger side rockers were solid. Got lucky.
#66 |
Re: 72 Plaid Sub
July 2018 - Cleaning up the firewall with some nice smooth bead rolled panels from Slosh Tubz.
#67 |
Re: 72 Plaid Sub
Bret, just checking in on you and the project. I've taken a break on Instagram, but last I was on there you thought you were close to paint. How are things coming?
#68 |
Re: 72 Plaid Sub
Going good over here, just not as much progress as I would like. I had some family heath issues that took a lot of my time early this year, and then I decided to replace some more sheet metal on the burb that I wasn't happy with. I'm real close paint now. I should start painting the interior within the next 2-3 weeks.
#69 | |
Re: 72 Plaid Sub
#70 |
Re: 72 Plaid Sub
One question for you. How is the fit of your passenger doors? I was installing weatherstrip on mine and noticed that although the body of the door is decent, the window area is terrible.
#71 | |
Re: 72 Plaid Sub
The weather strip attaches to a pinch weld in the door jamb. I smacked that pinch weld in a little with a dead blow hammer so it wasn't pushing out so hard on the window frame, then reinstalled the weather strip and checked the fit until it looked right. Had to do the same in several places on the other doors as well. Those window frames will bend a little, but I'm sure its much less stressful bending them in the body work stage than when they're painted. Hope this helps. |
#72 |
Re: 72 Plaid Sub
More July 2018 mock up and bare metal panel alignment.
#73 |
Re: 72 Plaid Sub
Got some Trique Mfg. Altman Easy Latches for the doors. Decided to cut them apart and weld them flush instead of bolting them in.
Discovered something weird about suburbans during this process. The suburban passenger door striker plate is different than the truck. As you can see in the picture, the bolt holes don't line up and the inside edge of the plate had to be ground down to fit. |
#74 |
Re: 72 Plaid Sub
NICE! Altman has been working on a Suburban set for a while, but I'm not holding my breath. How did the 3 door close once you finished the mod?
#75 |
Re: 72 Plaid Sub
Doors close much easier. I mocked everything up and did all bodywork with the door seals in place. I just figured I would sacrifice a set of seals through the build, so I didn't have to worry about the doors being so tight in the end.
