05-23-2020, 12:11 PM | #1 |
Quadrajet TV cable
I have just installed a 700R4 in my stock 68 C20 with a quadrajet.I need to be able to connect cable to carb correctly. I have bracket to hold cable at correct angle the goes on back of carb but I need the part with stud on carb. I have not found any after market "corrector" or adapters that spell out for Quadrajet. What have you guys had luck with? I have been looking for a qjet from that era to get the part I need but not having any luck. Thanks
05-23-2020, 12:22 PM | #2 |
Re: Quadrajet TV cable
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-23-2020, 12:24 PM | #3 |
Some studs here.
Not sure which you need, but a source for them. https://quadrajetparts.com/quadrajet...-c-128_52.html And maybe some here. They’ll likely know what you need. https://www.bowtieoverdrives.com/ |
05-23-2020, 12:43 PM | #4 |
The correct carb (1982) has a arm on the main throttle shaft,driver side, that has correct geometry and the stud that cable hooks to. The older Qjet does not have it ,there are many items listed out there but have yet to find one the says for Qjet. My original thought was find a 82 Qjet and use the throttle shaft from that carb on the older one.
05-23-2020, 12:52 PM | #5 |
As previously stated. Bowtie Overdrive has something for every application.
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-23-2020, 07:08 PM | #6 |
Moderator
I would think that Edelbrock has an adapter. Have a look at their stuff.
