Old 05-24-2020, 02:57 PM   #1226
tim_mc
tim_mc's Avatar
Re: What did you do to your truck today.The 3rd chapter
Today I FINALLY got my new Edelbrock AVS2 650cfm carb running correctly on my new 350 engine.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 05-24-2020, 03:48 PM   #1227
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I drove mine to the store. The girlfriend wanted Tri Tip for her birthday dinner.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-24-2020, 05:59 PM   #1228
OregonNed
OregonNed's Avatar
Today I started the process of fixing the weep hole leak (when parking uphill) from my transmission. The vent tube up above is clear so I pulled the drive shaft And tail housing. From photos I’ve seen I expected to see some sort of inner seal or o ring but nothing present or much of a groove for one where the splines Start. I’m not even sure if mechanically that would seal the driveshaft yoke.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-24-2020, 10:10 PM   #1229
SoCoC10
SoCoC10's Avatar
Spent the day at the media blaster. Of course no rain in the forecast yet I was dodging drops on the way back to the shop.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 05-24-2020, 11:20 PM   #1230
External
External's Avatar
After finally massaging in new break lines, installing the new booster, master cylinder and shiny new stuff.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 05-26-2020, 03:43 PM   #1231
OregonNed
OregonNed's Avatar
Got the bearing surfaces cleaned up on my driveshaft and yoke. Installed the tailhousing back on and waiting for new Spicer joints to arrive today. Should have a non leaking yoke now.
Old 05-30-2020, 10:00 PM   #1232
allchevy58
allchevy58's Avatar
Thursday evening and today started sanding. Don't think I'll find any bondo.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-31-2020, 12:34 AM   #1233
Quikshft
Quikshft's Avatar
Today I am closing the door on my gear change project. Went from 3.07 to 4.11. Granny first gear used to have some value with my small travel trailer, but I'm afraid it is now rendered useless and starts in second gear will work fine. I will go from about 1700 rpm in fourth to a more reasonable 2400 rpm at 55 mph with my 33 inch tires.
Quikshft is offline   Reply With Quote
Old 05-31-2020, 04:18 PM   #1234
truckdude239
truckdude239's Avatar
i installed new matching door locks and ignition lock so id have 1 key since i couldn't find my door keys which got lost over the last 8 years if ti being tore apart.. of course i found the door keys last night after the new locks showed up...
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-31-2020, 04:35 PM   #1235
Ol Blue K20
Don't feel bad, I have the same kind of luck......basic Murphys Law......
Dale
Old 06-01-2020, 12:07 PM   #1236
Grumpy old man
Grumpy old man's Avatar
Added some CPP disc brake calipers .
Old 06-01-2020, 12:51 PM   #1237
67C10Step
67C10Step's Avatar
Just stared at mine over the weekend to get an idea of what to tackle next. Wife got me a new set of body mounts for anniversary so that's on the list. Want to knock the front end out but waiting to order and get parts here first.
Did paint my old 5x12 utility trailer though. Not a great job but it is one color now.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-02-2020, 08:02 AM   #1238
66clow
66clow's Avatar
Finally posed in front of the old Chevy sign.
66clow is offline   Reply With Quote
Old 06-02-2020, 10:16 AM   #1239
RodnRudy
RodnRudy's Avatar
I installed my new DUI distributor Sat. Put in new plugs gaped at .050 and readjusted the timing to 14*BTDC . Total advance is 34* at 2500rpm. Also changed the vacuum advance to ported and reset the idle mixture with my vacuum gage. Truck is more responsive now and just seems to run better.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 06-03-2020, 01:14 PM   #1240
CryingJoker
I went and pulled the wheels off of my great grandfather's 70 stepside we have had in storage for years. Figured with being furloughed from work right now it gives me something to do. Had the tires removed and since 50 years is hard on the wheels I'm sandblasting and painting to freshen up. I've got some extra tires that hold air and will have them put on the put on the truck and load on a trailer to bring home. Fun project I've been looking forward to for a while and putting off almost as long.
03 s-10: daily driver
94 s-10: late model toy
70 c10: starting frame off resto
80 c10: for sale just collecting dust
94 c1500: hauler to and from
55 chevy: hot rod project jus reborn
CryingJoker is offline   Reply With Quote
Old 06-03-2020, 02:08 PM   #1241
Ol Blue K20
More pics please....
Dale
Old 06-03-2020, 02:25 PM   #1242
CryingJoker
Hoping to get the tires mounted by the weekend and bring the truck home. Truck is going to need a good bit of bodywork. It was the last vehicle my great grandfather ever bought and he left it to my sister upon his passing. She wasnt old enough to drive so dad bought it from her. He drove it until about 92 and parked it from a flat and needing carb rebuild.
Old 06-03-2020, 02:54 PM   #1243
OregonNed
OregonNed's Avatar
Giving my granddaughter a tour of mine
Old 06-03-2020, 06:18 PM   #1244
zicc1835
zicc1835's Avatar
your Blessed Grandpa.....
zicc1835 is offline   Reply With Quote
Old 06-03-2020, 06:28 PM   #1245
Ol Blue K20
It's hers now!
Dale
Old 06-03-2020, 06:35 PM   #1246
bill3rail
bill3rail's Avatar
No pictures, but I installed front disc conversion with power booster. New tie rods, upper and lower ball joints and stainless front brake lines.
Still need to adjust the alignment and get the leaks stopped!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 06-03-2020, 06:39 PM   #1247
Ol Blue K20
No pics?.....didn't happen......
Dale
Old 06-03-2020, 07:06 PM   #1248
Boog
laying low
Boog's Avatar
I've been up to my arm pits in the heater/ac parts lately. Cleaning and more cleaning. I made a trip to a jy today scouring parts trucks for things left I might could use. They're picked pretty clean and they haven't added any more 67-72 trucks in several years. It's getting harder to find used parts.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-04-2020, 10:58 PM   #1249
SRU1436
Replaced the grill emblem. The original was missing the center blue portion which I had a piece of cardboard with painters tape. It didn’t look bad but always kinda bothered me.
SRU1436 is offline   Reply With Quote
Old 06-05-2020, 12:52 AM   #1250
basketcase
basketcase's Avatar
Painted my front inner fenders a couple days ago and mounted the driver's side and fender today. Worked on the right side wiring some and the starter heat shield. I would have been surprised if I bought one I didn't have to modify.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
