![]() Join Date: Jan 2011
Re: Collapsible intermediate shaft?
That may work. On any adapter I use if it is not splined it gets welded or pinned. I do not trust the set screws.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#2 | |
Also be sure to re install the ground connector from the lower shaft to the steering box across the rag joint or your horn won't work. |
![]() Join Date: Feb 2016
I read on CPP website their collapsible shaft/ u joint is not recommended for stock columns.
So do we do? Im confused I have the 3/4, 36 spline gear box |
