Headliner
My truck was a 'fleet' truck. 6 cyl, 3 spd, no frills like a radio, cigarette lighter or dome light. Also no headliner. Can I add one now? Does it glue to the roof or use screws?
Silence is golden, duct tape is silver. - Scott |
The original headliners were glued in and also held in with chrome trim that would go around the edge of them. The only problem is, the holes for the trim are oval-shaped (very hard to duplicate). It suppose it would be possible however.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
It will take some time to cut out all the mounting holes for the trim piece that keeps it on but it is possible. You pretty much need a truck right there for you to copy the measurements from. The holes are oval so you have to drill some holes then file between them.
It wasnt to long ago that this subject was brought up. 69 if I remember right was the first year of the headliner. Putting this into the earlier cabs is a little tricky putting in the chrome strip but is doable. You can also use a good Apholstery adhesive and put it in place. Some members have done this and which case I will be doing soon as well. I like the idea of the trim but have opted to do it without it. I have the new headliner but yet havent installed it yet. My helper (14yr old son) has taken up a job this summer as a counsler helper isnt home to much to help me..
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
you can also buy some chrome/silver pipeing or edgeing as well which I have seen and it looks really nice.... also saw one with black material and then an Orange piping ..... it can be glued to headliner then headliner glued to roof....
Thanks for the input. I finally put in a dome light, but didn't want the stock look, so put in a dual map light unit from an RV store. It also never had bulbs in the side markers, so I may do something about that. I'll probably have to get a second battery for all this stuff - j/k.
thanks again. Scott
one set closer
http://www.brotherstrucks.com/tech/t...20INSTALLATION try this hope it's help.
![]() Join Date: Feb 2001
I put a headliner in my truck. Not a big deal! Glued the liner up then I broke the tabs off the headliner trim and used very small screws....
