Old 05-25-2020, 05:53 PM   #11
TrybalRage
Re: First time swap started
Originally Posted by dayj1 View Post
Gauges and senders are a matched pair. All senders are not the same. So, you can't run the old gauge and the new sender and expect an accurate reading.
Yes, it will work. You are most likely reading about swaps into vehicles that didn't have that functionality before the swap. It is something common to add into older swap vehicles.
I had a th350C (lockup) previously, so that must explain why I have the wiring for it.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
YouTube
TrybalRage is offline   Reply With Quote
