Old 06-24-2004, 10:29 PM   #1
8door
Not too old to learn
Power steering convertion
What is the difference between the early ram type power steering and later models and when did they change I think the later models did not have the ram assit on drag link. Is that right?.Can the earlies be converted . If so what are advantages.
The reason I ask is , as you can see I need to rebuild this one it leaks a lot and the thing is as loose a goose (what ever that means).
My truck is 68 C10
Chris
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 06-24-2004, 10:51 PM   #2
kwmech
Bolt in a regular PS box and center link.
Old 06-25-2004, 12:52 AM   #3
8door
kwmech. What years are the regular PS box off of?
Is the drag link the same?
Old 06-25-2004, 11:41 AM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
The ps box can come off any chevy 2wd truck, possibly up to & including '87. However, the later units have a different pressure hose fitting....it's metric and uses a o-ring seal. If you stick with '79 & older you should be alright. Find any center (drag link), either power or manual, from 67-70 years w/o disc brakes. They use a different diameter on the tie rod end studs w/ disc barkes (71-72). You'll have to find p/s pitman arm, they're not cheap new, are hard to find used.
Better yet, (unless you want it stock), find any 2wd '73 or later c-10 and get the ENTIRE front supension w/crossmember and put under your rig. I've not done it but have been told it is an easy swap. You'll have updated p/s and disc brakes to boot!
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 06-25-2004, 03:28 PM   #5
8door
Thanks Steve really appreciate the info.Any idea on costs of replacement pitman arm if I go that way?
I have gone to couple of my local parts stores and get " YA NO PROBLEM CAN GET YOU REBUILT UNITS NEXT DAY. Then I ask about the ram and I get the blank look.
"THE RAM OH YA.... WELL THAT YOU CAN PROBABLY FIND A GUY TO FIX IT"
Old 06-25-2004, 04:06 PM   #6
68speedalert
Semi-Senior Member
We bought one from O-Riley's Autoparts(may not be in CA) for around 60 bucks, if I remember right. I say it's high because most pitman arms for other vehicles are about half that price.
You might take the truck or pics to a tractor repair shop. If you can find some guys that have been around awhile, they might be able to rebuild the ram.
Just a thought, you could just remove the p/s ram & pump, find a pitman arm & center link and just a manual steering, if funds are tight. manual pitman arms shouldn't be too hard to find.
Steve
Old 06-25-2004, 04:54 PM   #7
8door
Steve: No O 'Riley parts in my area, but please read my post again today. I goofed and started a new thread instead of continuing this one.
Maybe I should just pull all the parts out of the truck, take measurements and start
digging.
Most places want a core anyway.Of courcs not the ram. I just talked with a buddy ( not a truck guy) but had his ram for a small Bobcat rebuilt for $40. I like that.
Money not the issue getting my truck in shape to drive is.
Thanks again. I'll post pics as I go may be someone else will benefit from this also.
Chris
