View Poll Results: If you had the option, which of these grills would you use? | |||
Original 66 painted grill | 1 | 20.00% | |
64-66 C60 painted grill | 2 | 40.00% | |
an original aluminum grill that needs to be restored | 2 | 40.00% | |
the repo aluminum grill that is now available | 0 | 0% | |
Voters: 5. You may not vote on this poll |
04-03-2020, 12:53 AM | #676 |
But Found Her 25yrs Later!
Re: pdx-sanity66
I love you, man!
So glad to see someone use as little of the patch as possible. So often you see them cut out the cab corner to fit the full patch piece. . Great progress!
04-04-2020, 02:03 PM | #677 |
Re: pdx-sanity66
Thanks for looking.
Thanks, man. I've tried to retain as much of the original sheet metal as possible and the cab corners are in pretty good shape.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-20-2020, 01:13 AM | #678 |
Re: pdx-sanity66
I ran out of gas and welding wire so I had to stop working on the hood until I can get more so I decided to assemble the bed since I have all the parts ready to go. A big job for one person but I managed with the help of my cherry picker
04-20-2020, 09:55 PM | #679 |
60-66 Nut
Re: pdx-sanity66
So did the reproduction longbed go together reasonably well?
04-21-2020, 12:17 PM | #680 |
Re: pdx-sanity66
The bedsides are a great fit All of the bolts aligned perfectly and everything squared up with no problems. I'm very happy with the results.
Thanks for looking in.
04-21-2020, 07:09 PM | #681 |
Re: pdx-sanity66
The portion of the flare is what scares me.
I worry the curve won't blend. How did yours turn out?
04-21-2020, 09:37 PM | #682 |
Re: pdx-sanity66
I had a lot of trouble with that part. Getting the curved lip to match took me a while. Actually that is the first version of this fender. I kept running into pitted sheet metal up the rear brace. I found a patch that was 17" long and matched up perfect. I think I got the patch from Brother's.
04-26-2020, 11:49 AM | #683 |
Re: pdx-sanity66
I got the bed mounted on the frame. All the cross sills to frame bolts all lined up with no problems. I'd like to get the bed wood and strips soon so I can get them fitted and marked for the bedside and front panel holes. I also got the tailgate trunnions I ordered. Very nice parts. I've also been working on the front of the hood. I'm almost ready for some primer.
04-26-2020, 08:49 PM | #684 |
Re: pdx-sanity66
Coming together.
04-27-2020, 01:20 PM | #685 |
Re: pdx-sanity66
Thanks, I've got most of the parts ready to install. I'm making sure it all fits together, then finish body work and hopefully get her painted, The hood is a big project and I still have the inside door bottoms. I am planning on a white roof so that will be the first priority to get painted so I can get the front and rear glass installed.
05-22-2020, 01:24 PM | #686 |
Re: pdx-sanity66
Now that I have the bed out of the way, I'm going back to the hood project. First is finishing the front of the hood and the brace. I media blasted the front area under the brace, the new brace, and the side patches. Everything welded up and a little filler to clean things up and it's on to the rear brace.
05-22-2020, 01:39 PM | #687 |
Re: pdx-sanity66
The rear brace was very intimidated for me and I almost decided to just replace the ends of the brace where the rust through was but I knew there was rust lurking under the brace so off it went. It wasn't as tough of a job as I thought it going to be and there was some rust that I media blasted then coated with rust reformer and rust encapsulater. Same procedure for the new donor brace. I welded in the patches where the brace mounts to the hood. Today I'm going to give the rear of the hood and the under side of the brace a couple of coats of extreme chassis black from Eastwood. Then installation of the brace to the hood. I have test fitted it and everything lines up very nicely.
05-22-2020, 01:42 PM | #688 |
Re: pdx-sanity66
more pics of the rear brace replacement.
05-23-2020, 03:14 PM | #689 |
Re: pdx-sanity66
Nice work! I am doing the exact same thing on my hood right now too
05-27-2020, 02:24 PM | #690 | |
Re: pdx-sanity66
here are some more of the rear brace replacement.
05-28-2020, 09:48 PM | #691 |
Re: pdx-sanity66
Looks great, nice work!
My '63 Restomod Build 283/4 speed, 4.5/7 static c-notched drop, disc brakes, power steering Instagram: in2engines |
05-29-2020, 04:29 PM | #692 |
Re: pdx-sanity66
Thanks you sir. I see your from the NW. Oregon or Washington? I'm formerly from Portland. I moved to Tucson 3 years ago but still have many friends and family up there.
! got all of the welding done on the hood and started smoothing things up this morning. Our Tucson heat wave ran me out of the garage at noon temp of 102.
05-30-2020, 10:00 AM | #693 |
Re: pdx-sanity66
damn Pdxhall, very nice work!! you are a craftsman. I to learn from your body work pics here, i am way off of your work, but trying. damn nice job.
05-30-2020, 11:38 PM | #694 | |
Re: pdx-sanity66
Sorry to get off subject, the work on the hood looks good though, I got some areas on our truck I need to get around to myself....
06-03-2020, 01:45 PM | #695 | |
Re: pdx-sanity66
I've got the hood brace and front nose replacement done for now, the underside needs to be painted and a lot more sanding, priming, repeat, repeat....on the front side. It's just too hot to paint right now with our heat wave we've having right now. The hood hinges/springs and latches are ready and waiting.
06-04-2020, 08:42 PM | #696 |
Re: pdx-sanity66
Since it is too hot to paint right now, I've been working on some other projects to get to the point that I can drive this thing. I pulled out the cab lights that have been in storage waiting for their day since I restored them. I made some new gaskets for the bottoms and set them on the roof of Sanity to see if I still liked them. I do. Any opinions or comments are welcome. I've also been working on my trans temp gauge and getting it mounted. I'll post some pics tomorrow.
06-04-2020, 08:53 PM | #697 |
Re: pdx-sanity66
Nice work! Love the lights. Reminded me that my dad had them on one of his trucks back in the day.
06-06-2020, 12:49 PM | #698 |
Re: pdx-sanity66
Thanks for looking. I liked them because they are painted not chrome and I think their shape is cool. The center light is slightly different than the outer 2 and apparently came that way as the set as the original pic shows.
06-08-2020, 10:49 AM | #699 |
Re: pdx-sanity66
Nice job on the hood. They can be tough to get just right. I couldn't tell but it looked like you filled the seams on the front. If so, how did you do it?
Big fan of the cab lights. And the bed looks great too... |
06-08-2020, 08:22 PM | #700 |
Re: pdx-sanity66
Thanks man, I did fill the seams. Mig welded everything up, ground it down, and smoothed things up with a skim coat of filler. I've still got some work to do on the front side.
