Old 05-30-2020, 08:55 PM   #1
reaperz1
Radiator suggestions
I have 72 c10 with a 402bb originally I have been restoring but got rid of the old shot one about 2 years ago to clean out some space in the garage. so I am looking for one to fit in the original brackets and big enough cool a 1000hp 454 bb going in it. I heard of be cool radiators. at this point not sure what size to get or if you guys recommend any other radiators that work just as good. also its hooked up to th400 with original trans lines
thank you
reaperz1 is offline   Reply With Quote
Old 05-30-2020, 10:12 PM   #2
Mike C
Mike C's Avatar
Re: Radiator suggestions
You should call the guys at DeWitts.
https://www.dewitts.com/
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-30-2020, 10:58 PM   #3
reaperz1
Thank you I will give them a call
Old 05-30-2020, 11:01 PM   #4
SRU1436
I used this direct bolt in for my stock 350. Works great!
http://www.speedcooling.com/Chevy-Truck/
SRU1436 is offline   Reply With Quote
Old 05-31-2020, 08:07 PM   #5
reaperz1
thank you I will look at them as well
Old 06-01-2020, 06:35 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Theses are pretty much drop in fit and the there is thread on someone installing one in a truck. Here is a link and there are a few more different posts on them as well.
http://67-72chevytrucks.com/vboard/s....php?p=8629490
https://www.coldcaseradiators.com/pr..._type/trucksuv
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-01-2020, 08:35 PM   #7
LS short box
1000 hp big block you are going to need the biggest radiator you can fit. Yes DeWitts is a good suggestion. I would check over on LS1 Tech their cooling section. Some of those guys a re running big hp engines.
Old 06-01-2020, 08:37 PM   #8
57larry
I have Cold Case in my 57 & 68 C10. no problems
57larry is offline   Reply With Quote
Old 06-01-2020, 08:54 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
How much horsepower are you pushing?
~Steven
Simi Valley, CA
