06-01-2020, 01:02 PM | #1 |
Re: 51 Chev on a S10 frame, named Dale
Hi Guys,
Installed new windshield glass yesterday. I was pleased that there was no rust in the window channel, and the process is straight forward and went smoothly.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
06-01-2020, 09:35 PM | #2 |
Proprietor of Dale's Corner
Looks awesome.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-02-2020, 10:43 AM | #3 |
Russ,
I could not get the middle bar back in without Mrs Tempest pushing the piece in while I was inside with the screw driver. I could get the bottom 3 started, but could not get the upper one. (as I need someone taller than 5'2" to push on the upper part of the chrome bar). I was pleased how well everything went together. Looks like 'Bickle' is coming along. Ol Blue K20, Dale, thanks.... I am happy with the outcome. just a slight ripple of the seal on the top in the middle, but hopefully some adhesive and sunshine will fix that.
06-02-2020, 11:49 AM | #4 |
also, I bent in a part of the firewall to accommodate the passenger side valve cover, after thinking about the wiring for the motor, I drilled a hole and rerouted the wires through it. I think it will make for a cleaner engine compartment.
I also ran the hydraulic line to the clutch through this area. .........making progress
06-02-2020, 12:45 PM | #5 |
Good use of the space.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
