Radiator suggestions
I have 72 c10 with a 402bb originally I have been restoring but got rid of the old shot one about 2 years ago to clean out some space in the garage. so I am looking for one to fit in the original brackets and big enough cool a 1000hp 454 bb going in it. I heard of be cool radiators. at this point not sure what size to get or if you guys recommend any other radiators that work just as good. also its hooked up to th400 with original trans lines
thank you |
Re: Radiator suggestions
Thank you I will give them a call
thank you I will look at them as well
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Theses are pretty much drop in fit and the there is thread on someone installing one in a truck. Here is a link and there are a few more different posts on them as well.
http://67-72chevytrucks.com/vboard/s....php?p=8629490 https://www.coldcaseradiators.com/pr..._type/trucksuv
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
1000 hp big block you are going to need the biggest radiator you can fit. Yes DeWitts is a good suggestion. I would check over on LS1 Tech their cooling section. Some of those guys a re running big hp engines.
I have Cold Case in my 57 & 68 C10. no problems
Who Changed This?
![]() Join Date: Jan 2013
How much horsepower are you pushing?
