Old 06-05-2020, 11:20 AM   #1
jaros44sr
jaros44sr's Avatar
T/C fluid
Just wanted to check what fluid you are using to fill up your transfer case? I have some ATF laying around and it would be nice to get rid of it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 06-05-2020, 12:55 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: T/C fluid
Assuming it's a 205, I have read most gear oils will work including ATF. Mine ran for years with ATF but anymore I use Mobil One synthetic 75W-90.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-05-2020, 01:46 PM   #3
jaros44sr
jaros44sr's Avatar
Re: T/C fluid
good point, yes it is a 205, figured that ATF would work, since a seal leaks and ends up in the T/C, just gotta check your trans fluid for low level
SAFETY FIRST
AS usual, off topic
Jim
Old 06-05-2020, 02:37 PM   #4
MJN
MJN's Avatar
Re: T/C fluid
synthetic gear lube, 75w90
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-05-2020, 04:19 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: T/C fluid
That's exactly what I dealt with for years! Transmission would slip due to low fluid -- top it off, and drain the excess from the transfer case!
- Mike -
RIP El Jay
Old 06-05-2020, 04:33 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Re: T/C fluid
80/90 Dino gear oil in mine, sm465 and np205 both
Tyler
Old 06-05-2020, 04:36 PM   #7
gmc684x4
Re: T/C fluid
80 90 gear oil is what is recomended for our trucks
Atf is used in newer trucks with much smaller bearing sm 265 205 tcase have large course ball bearings
gmc684x4 is offline   Reply With Quote
Old 06-05-2020, 06:06 PM   #8
Husker
Husker's Avatar
Re: T/C fluid
I am running ATF. The same as the TH350.
No problems
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-05-2020, 06:54 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: T/C fluid
Couple old threads if you're interested..... and there are more, just search.
http://67-72chevytrucks.com/vboard/s...d.php?t=278680
https://67-72chevytrucks.com/vboard/...d.php?t=559120
- Mike -
RIP El Jay
Old 06-06-2020, 10:47 AM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: T/C fluid
I think we have all done this....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-06-2020, 11:21 AM   #11
jaros44sr
jaros44sr's Avatar
Re: T/C fluid
well, let me give you alittle back story, when it was in the shop for the EFI, I asked how much tranny fluid goes in he said"6-7 quarts" so I put it in, my tranny leaked for a couple months, kinda caught most of it, so now I have a pan with about 6 quarts laying here, bright idea!!!!, lets put it into the t/c, It wont get spilled in my shop,and I can CYA when my son asks, what is in that pan, he doesn't come on this forum (jeep guy). so that why I asked
SAFETY FIRST
AS usual, off topic
Jim
