Old 06-12-2020, 05:33 PM   #1
pdxhall
pdxhall's Avatar
Seat hardware
Does anyone have a source for seat hardware such as the bolts that hold the upper seat to the lower? Also, the seat adjuster bolts for the same area?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-12-2020, 06:40 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Seat hardware
You mean like these? https://www.classicparts.com/1960-66...info/28%2D925/
The seat back bolts you'll have to find used I think. Contact Aspen Parts in Arizona. And that little adjuster too.
I took mine off and replaced them with nicer looking units, you'll still need the spacer though.
Old 06-12-2020, 08:03 PM   #3
The Rocknrod
Moderator
Re: Seat hardware
Wow
There is a spacer on this flange head bolt, their real proud of it - https://www.oldsobsolete.com/product...t-nos-3762931/
Old 06-12-2020, 08:14 PM   #4
pdxhall
pdxhall's Avatar
Re: Seat hardware
Originally Posted by The Rocknrod View Post
Wow
That is one of the bolts I'm talking about but there should be a better option...
The other one is the flat headed bolt that adjusts the tilt of the back. The first ones are the track mounting bolts and I've got that covered. Thanks.
Sanity'66
Old 06-12-2020, 08:18 PM   #5
The Rocknrod
Moderator
Re: Seat hardware
Never seen new ones on the seat back to seat bottom bolts.
The adjusters either.
Again call Aspen in Arizona.
Old 06-12-2020, 10:36 PM   #6
franken
Re: Seat hardware
Wow
I'm pretty sure I'd use a quality bolt and a bushing rather than pay $50. Then again I'm not sure what stress the bolt has/will have on it so maybe not.
To the OP, lots of special bolts, etc. are at the hardware/home store, but lots are from Asia.
