Active Member
![]() Join Date: Jan 2017
Re: Installing inner fender seals to firewall 1960-66 C10
I got staples from one of the usual classic car parts places. I think they came with the rubber seals. Then I held the piece in a vice and used a very small drill bit and held the rubber tight to the metal and drilled through the existing holes in the metal, into the rubber all the way through. I then used channel lock pliers to push the staple through and bend the ends over. They look perfect. I was dreading this step of my restoration but it ended up being pretty easy. Just be sure not to drill holes through your fingers!
Submariner616 1965 Chevrolet K20 350 4 speed manual |
#2 | ||
