Upper radiator hose
This might be a long shot, but is anyone here running a 7.4 vortec with 4 row radiator? I'm having a nasty time finding an upper radiator hose.
I tried one for a 96 7.4 in a c2500 and it might have worked if it were about 6 inches shorter before turning and heading to the radiator, and had the larger end there. Any suggestions other than cutting and splicing? The inlet housing points straight up...it's the only way it can go. ORielys is about to kick me out from going to the back and digging through their stock. |
![]() Join Date: Dec 2013
Re: Upper radiator hose
Can't quite picture what you need. My 70ss has a LC9 installed. this engine has the variable timing mechanism up front which puts it close to radiator. Also has VA one belt drive with high capacity water pump which exits toward radiator so I had to get hose with a 90 very close to end. Found hose below. Also the water pump had a smaller fitting than the radiator so I had to get a reducer which is below.
Gate makes these in 3 lengths - don't know the other numbers. Hope this helps. hose Gates 25808 1 1/2” reducer Gates 26390 1 1/2” to 1 1/4” |
What year pickup???
#4 | |
At the body shop.
My 99 crew cab with a towing package.
Wonder if the 98 tahoe 350 would work
" That didnt make it any newer " " Dont antique the equipment " |
#8 | |
The lower hose seems to be harder to find than the upper now ![]() |
