Help explain spindle/ball joint/tie rod choice
So I ordered new suspension with 73-87 drop spindles, ball joints, tie rods, etc. for my 68 c10 back in May but found out today they're on backorder until end of July. I'm told I can get the 63-72 everything now. Is it worth waiting on the new style? I'm leaning toward just going with the 63-72 stuff since its holding my build up. What is your advice?
Thanks, Phillip |
Re: Help explain spindle/ball joint/tie rod choice
Curious, who did you order from? Reason I ask is I am about to pull the trigger on the same setup and was planning on going with the 73-87 setup myself.
Personally, I'd wait but that is just me. I believe the ball joints on 73-87 are bigger in the tapered shaft that goes into the spindle. Not sure if that makes any difference or not but I would guess going from drum to disc does induce some extra stresses on the front suspension and steering components over drum.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#3 | |
If you’re buying the Performance online disc conversion kit the only thing 73-87 you’re getting is the spindle and ball joints. The tie rods will be a mix to adapt 73-87 spindles to 63-72. To go all 73-87 you’ll need to change the center link and get all tie rods.
In my opinion I wouldn’t sweat it. As long as you can get all the parts you need, that’s what I’d order.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
