Old 06-20-2020, 10:12 PM   #8
Captainfab
60-66 Nut
Re: 65 C20 to C10 changeover
I do not know if the C20 LCA shaft will fit a C10 LCA. I've never tried it......no reason to. Yes the crossmember is different as I stated before. There are no saddles to accept a round LCA shaft. I have a pic of a '63-'66 C20 LCA but it is apparently on my other computer.
Originally Posted by 69SCSS View Post
So as far as parts, are the upper control arms the same? Will the shaft for the lower control arm fit in the C10 arm, or is it larger also? Seems like I can swap the upper control arm ball joint, but maybe not?
Finding pics for this stuff has been tough, so any info you guys have on the c10/c20 differences will help a lot!
Here's something I was just wondering, is the actual crossmember different between c10/c20?
