Old 06-22-2020, 08:12 AM   #1
dennislbrooks
dennislbrooks's Avatar
Re: Rebuild 1972 K10 12 bolt or swap in 14 bolt Semi Float or Full Float
I do have a 14 bolt 9.5 SF 3.73 with G80 from a 90's SS 454 (not easily found around here) that was 5 on 5 but I redrilled for 6 on 5.5 on my 67. What other vehicles did the 9.5 SF 6 lug come out on?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 06-22-2020, 11:31 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
They could be had from 80’s-90’s light duty 3/4 ton trucks for sure. There may be more but I know the 6 lug 3/4 tons normally had the semi float 14. My dad has a 85 K20 that’s 8 lug with the semi float 14 too, so they were available in 5,6 and 8 lug.
Tyler
57taskforce is online now   Reply With Quote
Old 07-02-2020, 07:46 PM   #3
fishmunger
fishmunger's Avatar
Thanks for those bits of info TIMCHNE. I didn’t realize they were wider. I’ve always wondered why stock they came with a wider front than rear?
fishmunger is offline   Reply With Quote
Old 07-05-2020, 08:59 PM   #4
Mike C
Mike C's Avatar
Some 1/2 ton Z-71 GMT400 trucks came with the 9.5" SF in 6 lug as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
