Old 06-23-2020, 02:25 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Strange charging issue
Did you test it when it was running to get that 11.7v . Or did you test the batt.( running not running) To see what volts you got for both. check your fuses step 1 and your ground @ the fan motor and or firewall. One screw should make a connection to the fan body( no paint under the head of the screw then that screw should transfer to the firewall body, if has the one brass spade ground. The other spade with the rubber would be +.
If your connections are good. And your batt still under 12.5 it maybe not holding a charge.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
