![]() Join Date: Apr 2017
Steering Column Placement
I recently got a rebuilt non-tilt floor shift steering column from Randy500 to install as a part of my front end swap. I figured now was the best time so the entire steering system was solid.
I installed it without issue, except for this one small detail. There are two “nubs” on the column that look like they sit in the two holes on the bracket on the firewall, but I can’t get those “nubs” to sit within that bracket. It looks like the go almost all the way, but won’t seat in there. I can’t get the column to go any further into the truck. It may be solved by someone simply posting a picture of this area on their truck. Ignore the hose clamp. My stock strap was broken and this was the next best thing I had. Thank you in advance! ![]()
1968 GMC C2500 Long Bed Fleetside |
Old member
I'm not going to say 100% they are not suppose to but here is my stock steering column and the numbs aren't in the holes either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Almost Satisfied
![]() Join Date: Mar 2002
Re: Steering Column Placement
I couldn't get them in mine either...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Thank you both SO MUCH. I felt like they should, but I can't remember what my old column looked like (and it probably wasn't in the right place anyways...)
laying low
![]() Join Date: Mar 2001
I believe those bumps are there for the bracket to clamp above them to help prevent the column from being pushed up into the cab upon front end impact. Stops if you will.
#6 | |
Old member
![]() Quote:
Good point. You maybe right sir. ![]()
