Old 06-25-2004, 10:37 PM   #1
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
anyone know how to check the ratio of a rear axle w/o taking it apart
someone has asked me if i would sell them the axle in my parts 74-i will on the condition its not like a 3.73 geared axle or something i may want in the future.so can anyone tell me how to check the ratio of an axle without taking it apart.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 06-25-2004, 10:54 PM   #2
Russell
Professional Grade
Russell's Avatar
You can put the truck in neutral, and rotate the wheels seeing how many times the driveshaft turns for each wheel rotation...
Not sure about the ratios though, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-26-2004, 12:02 AM   #3
jimfulco
Chock the front wheels so the truck won't roll. Put the trans in neutral. Make sure the parking brake is off. Jack up ONE rear wheel. Turn that wheel TWO full turns while counting the number of turns the driveshaft makes. The number of turns is your gear ratio.
Wheel wouldn't turn easily? You probably have a limited-slip (posi) rear end. In that case, jack up BOTH rear wheels, & turn them ONE full turn. Count driveshaft revolutions to get your ratio.
2-3/4 turns = 2.73
a little over 3 turns = 3.07 or 3.08
3-3/4 turns = 3.73
etc.
jimfulco is offline   Reply With Quote
Old 06-26-2004, 01:07 AM   #4
1974ChevyC10
i forgot to mention that the truck doesnt have a transmission in it so will it make any harder to check the rotations of the driveshaft-it does have the driveshaft in it just no trans.
Red-1978 C10 LWB
Old 06-26-2004, 08:22 PM   #5
TIMSPEED
TIMSPEED's Avatar
If you know it's the original gears, then you can check the code. It's on the front of the passenger side axle tube, at about the 2'o'clock position, about 8" out from the pumpkin.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-26-2004, 11:00 PM   #6
jimfulco
Probably best to disconnect the driveshaft so it doesn't flop around, or get somebody to hold it up for you.
Old 06-27-2004, 03:04 AM   #7
1974ChevyC10
the truck has a 2 piece shaft will that make it any easier.
Red-1978 C10 LWB
Old 06-27-2004, 11:35 AM   #8
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Why not just pull the cover and read the number of teeth off the ring gear? I know it's not what you wanted, but its the most surefire method to determine ratio and really isn't that big of a deal...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 06-27-2004, 04:33 PM   #9
1974ChevyC10
i dont have a problem with pulling off the diff cover but in order to get the accurate gear ratio its my understand you have to count both the number of teeth on the ring and pinion gear then divide the larger number by the smaller number-am i correct or way off base here and in order to get to the pinion gear dont you have to take the whole center section of the axle out?
Red-1978 C10 LWB
Old 06-27-2004, 05:14 PM   #10
ElGracho
ElGracho's Avatar
Most ring gears will have the number of teeth on the ring gear and the pinion gear stamped on them. I've seen this on all of the 10 or so factory diffs I've seen apart. You see something like 41 10 or the corresponding numbers for your particular gears. Counting teeth shouldn't be necessary.
Old 06-27-2004, 06:10 PM   #11
1974ChevyC10
i see-i was not aware of that information.thanks for the tip.now on my weekend ill get down to my dads shop and see what i got
Red-1978 C10 LWB
