Old 06-27-2020, 10:50 PM   #1
tdangle
tdangle's Avatar
Bet you don't see this often
Not only appears to be original, it has something else.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-28-2020, 12:10 AM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Bet you don't see this often
Tried removing the straight slotted screw yet?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-28-2020, 12:24 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Luckily I’ve never had a problem removing the slotted screw. It’s pretty short and doesn’t have a lot of threads.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-28-2020, 11:54 AM   #4
tdangle
tdangle's Avatar
Yep,
If it's tight, use an impact screwdriver. Works great!
Terry
Old 06-28-2020, 11:59 AM   #5
72c20customcamper
72c20customcamper's Avatar
Mine came out with a few taps and regular screw driver
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-29-2020, 02:58 AM   #6
toolboxchev
Originally Posted by tdangle View Post
Yep,
I install them that way also. Most of the newer drums do not have these machined into the drum.
Its there for a reason. Freakin Aftermarket!
toolboxchev is offline   Reply With Quote
Old 06-29-2020, 07:43 AM   #7
Minkota
I have worked on many of those. that slotted screw is one reason I own an Impact Driver (screwdriver you hit with a hammer and the tip turns when it is hit).
Minkota is offline   Reply With Quote
Old 06-29-2020, 10:51 AM   #8
weim55
I’ve NEVER seen a 67-72 8 lug with a slide on rear drum. My ‘50 3600 w/ HO52 is that style. Is this on your ‘70?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 06-29-2020, 12:20 PM   #9
MJN
MJN's Avatar
I've seen them on Dana 60's but not Eaton rear axles.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-29-2020, 12:40 PM   #10
tdangle
tdangle's Avatar
Yes, Dana 60 on my 70 C20
Terry
Old 06-29-2020, 02:00 PM   #11
weim55
Wow, I think of all the brake jobs I did on these trucks back in the day I never ran across a single one with a slide on eight lug rear brake drum. Must be a Dana 60 Thing. Luck of the draw I never worked on that particular application.
Old 06-29-2020, 03:12 PM   #12
RichardJ
I have two Dana 60's, but only the '67 has the slotted screws. The '69 does not, but it is a Roadrunner with a 5-lug, semi-floating, Dana 60. He,he.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 06-29-2020, 04:48 PM   #13
tdangle
tdangle's Avatar
and I assume 4 speed. 383 or 440?
Terry
