Old 07-01-2020, 08:49 AM   #1
HeavyHauler
Anybody else get alot of bumpsteer after lowering your truck? How did you correct it?
I lowered my 1968 Chevy C10 4.5 inches in the front and 6 inches in the rear then had it wheel aligned at a local repair shop.
I am now getting alot of what I think is called bumpsteer. When I hit a bump or pot hole the wheels will want to switch directions on their own without steering input and then I have to man handle it to keep it going straight.
Anybody had this happen and what did you do to correct it?
I used the following parts to lower the truck along with converting to 4 wheel disc brakes.
Front: Early Classics 2.5 Drop Spindle with 2 inch lowering springs from Western chassis. My truck came from the factory with 1 1/16 sway bar but i added poly bushings. I replaced ALL bushings,ball joints,tie rod ends,pitman arm and idler arm with new over the counter auto parts stuff from Oreillys and Autozone. Installed 5 lug front disc brake kit from Early Classics. New shocks from Bell Tech.
Rear: Western Chassis 6 inch drop springs with double adjustable track bar. Installed new 5 lug conversion axles and rear disc brake kit. New shocks from Bell Tech.
HeavyHauler is offline   Reply With Quote
Old 07-01-2020, 09:17 AM   #2
67/Heaven
67/Heaven's Avatar
Re: Anybody else get alot of bumpsteer after lowering your truck? How did you correct
Check this post
http://www.67-72chevytrucks.com/vboa....php?p=7953452
67/Heaven is offline   Reply With Quote
Old 07-01-2020, 09:23 AM   #3
americanmusc1e
americanmusc1e's Avatar
Did the shop you had it aligned at give any feedback? Mine's only lowered 2" on the front (cut coil springs, not optimal), but I don't have any bumpsteer issues.
I know excessive toe out can cause issues like that and my first thought was to take it to an alignment shop. Did the alignment shop you took it to have any experience with lowered vehicles?
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 07-01-2020, 10:00 AM   #4
jonmc56
jonmc56's Avatar
Yes, happened to me after lowering my truck (4/6 drop using ECE drop spindles & springs). Turned out that I had installed the drag/center link in backwards, which is very easy to do. After I corrected the center link, it was completely resolved.
'69 C10 CST
'68 Chevelle Malibu
My 69 CST Build Thread
jonmc56 is offline   Reply With Quote
Old 07-01-2020, 03:16 PM   #5
68 P.O.S.
On mine, when I did a 4-6 drop, I rebuilt the front end with Moog parts as well. That tightened things up and afterwards I added a Moog ssd10 steering stabilizer. It helped out a good bit, but wasn't a 100% cure by any means.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-01-2020, 06:23 PM   #6
HO455
HO455's Avatar
Here is a link to my repair thread. Post 273 I wrote about my bump steer testing and posted my alignment specs. Now my truck has factory spindles so that should mean it should experience less tie rod angle for any given spring height.
I have seen spring compressors used when checking for bump steer in the down direction and well up is easy.
There are plenty of threads in the suspension section and of course the ever popular "Make it handle" thread where bump steer is discussed and remedies are shown.
https://67-72chevytrucks.com/vboard/...698377&page=11
RIP Bob Parks.
Old 07-01-2020, 10:38 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Any chance you also changed wheels and / or tires? In particular, wheels with more negative offset can contribute to bump steer. Wider tires up front (and some tire brands) can cause tramlining, where the tires tend to follow cracks or seams in the pavement. Not quite the same as bump steer, but might make it feel even worse.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-02-2020, 01:26 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I bet the centerlink is on backwards.
The inner tie rod nuts should be on the front side of the centerlink.
Keith
Convert to disc brakes.
Old 07-02-2020, 08:47 AM   #9
RustyPile
RustyPile's Avatar
In addition to all of the above, adding high amounts of caster will aggravate bump steer..
RustyPile is offline   Reply With Quote
Old 07-02-2020, 06:52 PM   #10
SCOTI
SCOTI's Avatar
Several good suggestions worth checking out posted above.
What were the alignment numbers? They should have given you a print-off for your records.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-06-2020, 01:47 PM   #11
HeavyHauler
Here is a pic of the passenger side of the centerlink. Hopefully you can tell me if I installed the centerlink correctly from this pic.
Old 07-06-2020, 01:49 PM   #12
HeavyHauler
I just posted a pic of mine to see if you guys can let me know if installed correctly.
Old 07-06-2020, 01:52 PM   #13
HeavyHauler
Yes I have new wheels and tires. On the rear 20x9.5 with 275/45/20 and on the front 20x8 with 255/45/20. They are US MAG Ramblers.
Old 07-06-2020, 01:54 PM   #14
HeavyHauler
They gave me a print out but I dont know what the numbers mean as far as how it makes the truck handle.
Old 07-06-2020, 01:55 PM   #15
HeavyHauler
I just posted a pic of how I mounted my centerlink.
Old 07-06-2020, 03:58 PM   #16
SCOTI
SCOTI's Avatar
Take a picture of the alignment printout & post it as an image attachment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-06-2020, 04:41 PM   #17
Custom 68
Custom 68's Avatar
It looks like your center link is correct but check out this link.
http://67-72chevytrucks.com/vboard/s...d.php?t=400205
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
