Old 07-01-2020, 12:17 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1989 Suburban 2WD 3/4 to 1/2 Swap?
Originally Posted by SCOTI View Post
The upper a-arm studs are likely larger on the 3/4 ton so the shafts might need to be drilled out to utilize the 1/2 ton arms as is.
The other option would be to put a 1/2-ton ballpoint in the 3/4-ton UPPER a-arm.
You can’t do that with the lower a-arm because the 3/4-ton ballpoint hole is larger than the 1/2-ton version.
I would still not swap the crossmember itself.
Keith
Convert to disc brakes.
