Old 07-05-2020, 05:06 PM   #1301
CG
BlahBlahBlah
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by samkost View Post
Since I procrastinated on this windshield, I had called Tahoma Glass to set up my appointment.
Turns out Tahoma Glass, a long time top rated glass shop for all Classic vehicles in my area has closed his doors and retired.
However they did answer their phone and recommended a local glass installer, Jakes Glass LLC.
Jake has installed many trimmed windshields on C10’s and has his method down a little different than I have seen on some installation videos.
Jake supplied the Precision gasket and the Furyuro (sp?) windshield.
Him and his assistant had the job done in under 2 hours.
I recommend him and his work.
Jake has an Instagram account.
Jakes Glass LLC.
Ph.# 253-666-2661
Happy 4th!
Ill have to give him a shout. I have an NOS gasket and Ill have to figure out how people are polishing their trim. I think LocDoc said do it while its still in the rubber before you change it out. And then dremmel and polishing compound of some sort. Do you know if he put extra sealant in it, or did he just use the gasket?
Old 07-05-2020, 10:06 PM   #1302
67C10Step
67C10Step's Avatar
Pulled my truck out of the shop and gave her a quick wash. Cleaned up her spot good and then made the leap and took the first step in disc brake conversion. I have all the front steering and suspension removed. All that remains is the upper and lower A arms on both sides. Ran out of gas and called it a day.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-06-2020, 10:38 AM   #1303
Davidf
Finally finished rebuilding seat and recovering. Now the refurbished interior is nearing completion. Just need to finish trimming carpet, install seat belts, door panels, head unit, and steering wheel.
Reclaimed R12 refrigerant so I could disassemble a/c system enough to remove core support for rust repair (battery area) and repaint. Temporarily buttoned a/c system back up so I could evacuate to keep moisture out and re-use filter/drier. Going to change expansion valve while I have it opened up (evaporator flooding issues). No, I am not doing a BMW engine swap!
Davidf is offline   Reply With Quote
Old 07-06-2020, 11:02 AM   #1304
KMC3420
KMC3420's Avatar
Originally Posted by 67C10Step View Post
Pulled my truck out of the shop and gave her a quick wash. Cleaned up her spot good and then made the leap and took the first strep in disc brake conversion. I have all the front steering and suspension removed. All that remains is the upper and lower A arms on both sides. Ran out of gas and called it a day.
You may need a bigger fan! Looks like your body panels are nice and straight, wont be too long and you will be running down the road. I am ready for fall, much more enjoyable to work on trucks, or outside in general.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 07-06-2020, 12:37 PM   #1305
samkost
samkost's Avatar
Yes, he used a new improved sealant he recommends and guarantees.
I polished the trim myself.
Call me cheap and crafty but I used a variable electric speed drill with a locking trigger button.
I put the drill upside down with the trigger in the up position in my bench vice and used the cheapo Harbor Freight cotton buffing wheels.
I started by taking some 1000 grit wet finishing sanding paper for taking down any fine scratches/blemishes. The trim is all stainless steel and being careful when polishing is pretty forgiving.
Being careful to not bend, keep your hands close together on the section you are polishing and keep moving to avoid heat build up when buffing.
Hope this helps everyone out.
samkost is offline   Reply With Quote
Old 07-06-2020, 12:43 PM   #1306
samkost
samkost's Avatar
[QUOTE=Davidf;8769647]Finally finished rebuilding seat and recovering. Now the refurbished interior is nearing completion. Just need to finish trimming carpet, install seat belts, door panels, head unit, and steering wheel.
Thats looks great Davidf !
I'm on this same pathway
Sam
Old 07-06-2020, 01:02 PM   #1307
67C10Step
67C10Step's Avatar
Short of an AC fan I don't know if a bigger fan would do much more than blow more hot, humid air over me! I have an exhaust fan near the peak of the roof in the shop I kick on as well to pull a bit more air through but it's awfully loud.
I've got my list of items to get, just ordered some Moog cross shaft kits and new from springs from Rockauto. Will get my conversion kit on order in a week or so. Got lots of cleaning to do before it goes back together.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-06-2020, 01:11 PM   #1308
Boog
laying low
Boog's Avatar
Bill I may have missed it but are you lowering it at this time or going back with stock suspension?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-06-2020, 01:27 PM   #1309
KMC3420
KMC3420's Avatar
haha, any air is better than no air, yesterday was a no air flow kind of day. Getting past the cleaning part is when the fun begins, when you can start putting on new parts. I wish ECE was still around, made it easy to one stop shop.
Keagan
Old 07-06-2020, 02:36 PM   #1310
67C10Step
67C10Step's Avatar
Boog,
Lowered it 4" in the rear and plan on 2-1/2" drop spindles in the front. I did the shock relocate in the rear and adjustable trac bar but wanted to keep front steering and suspension geometry which could use standard length shocks. I didn't want any radical lowering, just enough to make the stance lower and level.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-06-2020, 02:49 PM   #1311
Boog
laying low
Boog's Avatar
Ah ok. It should drive nice with that setup.
Boog
primer is finer
Old 07-06-2020, 07:09 PM   #1312
Davidf
[quote=samkost;8769701]
Sam
Thanks Sam...let’s see some photos!
Old 07-06-2020, 07:39 PM   #1313
samkost
samkost's Avatar
Getting closer Davidf !
I still need to upholster the bench with the Black with Orange and Black Houndstooth cover, DynaMat , Carpet, door panels and install the 3 point belts.
Old 07-06-2020, 11:37 PM   #1314
UNEASYRIDER
UNEASYRIDER's Avatar
Chillin with the shop dog.
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline   Reply With Quote
Old 07-06-2020, 11:41 PM   #1315
3757chevy
3757chevy's Avatar
Cute.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 07-07-2020, 04:33 AM   #1316
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Writing this at 02:30. I drove mine to work tonight so when I see it waiting for me in the morning it'll make me smile after doing six 12 hour night shifts in a row and now can enjoy her the next few days.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-07-2020, 07:05 PM   #1317
66clow
66clow's Avatar
Made some covers for the side of my seat. Think I'll do a bead roll around the outside of the holes.
66clow is offline   Reply With Quote
Old 07-08-2020, 05:10 PM   #1318
72c20customcamper
72c20customcamper's Avatar
Started the cowl gutter. Was going to shave it but decided against it . More pics to follow on the gutter channel. I made a die from wood and made the hump area so far the rest is just bending and using the metal stretcher and shrinker.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-08-2020, 07:58 PM   #1319
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great! Very nice truck
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-08-2020, 08:08 PM   #1320
BigBird05
Mine looked like that when I started. I found some very bad rust that was hidden under the cowl panel that I couldn't see until I removed it. I'm glad I went the extra mile and removed the cowl or I would have had water issues after all of that hard work.
BigBird05 is offline   Reply With Quote
Old 07-09-2020, 09:42 AM   #1321
67C10Step
67C10Step's Avatar
Got home late after a trip to power plant in east AR so all I did was unbox my new front springs and remove the upper passenger side A arm. Got the cross shaft ends loose on the bottom A arm so I can now take the U bolts off and drop the arm. It was hot, I was tired, and called it a day.
My new cross shafts should be here today. Ordered those and the new springs from RockAuto. New parts on the work bench motivates me. Even though these are weeks, possibly months from installation.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-09-2020, 11:13 AM   #1322
KMC3420
KMC3420's Avatar
You probably already know this, but I would opt for the 9/16" lower cross shaft u bolts while you already have it apart, unless you have already done this mod.
Mod Thread
Dorman 13503 U Bolts
Keagan
Old 07-09-2020, 11:41 AM   #1323
67C10Step
67C10Step's Avatar
Mod Thread
Yep, on my list to do upon reassembly. Thanks for the information as I was going to go look for it.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-09-2020, 06:58 PM   #1324
72c20customcamper
Welded up the gutter. While I was cutting out the rot I used the borescope to look inside the cowl actually real clean . The prior owner had put screening on the cowl cover so there was nothing in there . But they never cleaned the gutter . Was packed with dirt and pine needles when I got it.
Spent the day cutting fitting and welding couple of spots look bad but they are solid just rusty. A little more grinding and sanding ,a little filler and some seam sealer and I'm calling it done
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-11-2020, 02:44 PM   #1325
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Long story short I recently removed a ton of paint off the evaporator housing. 20-25 minutes oven cleaner, followed by 5 hours of patience and lacquer thinner. Ecstatic they're in great shape for just polish. I have a general cleaning to do yet, and they'll see a fiberglass polish I hope to see as the ticket.
More than that the painter took my cab, cowl & hood today, and dropped off this bed and tailgate.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
