Old 06-12-2020, 04:01 PM   #51
93M6Formula
Re: 1982 K10 6.2 Diesel build
Originally Posted by focusedontheprize View Post
The truck looks great and that color scheme is definitely growing on me - I really am liking it now. Regarding your K10 diesel frame project, that is the best way to go if you can and the best of both worlds.
Thanks! I feel the same, I was really considering a color change but man it really does look sharp when cleaned up, I think I will keep the original color.
And yeah I think it makes good sense, I hate my projects sitting around so if I can decrease downtime thats what I want to do.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 07-06-2020, 11:15 AM   #52
LT7A
You've made a lot of progress. That rig looks ready for business.
Old 07-07-2020, 10:18 AM   #53
93M6Formula
Thanks! She's been putting in work and averaging 17-18 MPG in town so far. Want to start on my NV4500 swap soon once I find some pedals for it.
Old 07-08-2020, 09:37 AM   #54
93M6Formula
No point owning a truck if you don't use it.
Old 07-08-2020, 02:54 PM   #55
Matt Man
Matt Man's Avatar
Love the color combo. Will be following along.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 07-31-2020, 11:02 AM   #56
93M6Formula
Not much to update recently but finally got around to replacing balljoints, stabilizer and tierods. Was dreading it but it really didn't take long at all and everything came apart easily. Brake pads were basically to the metl but luckily the rotors were in really good shape.
Old 07-31-2020, 11:17 AM   #57
93M6Formula
Also went and grabbed the 1986 chassis I bought. Got it from my uncle who was going to build another square but gave up so i got the 79 C20 cab and front clip with it. Pretty damn good shape but I will be selling it.
Old 08-25-2020, 02:43 AM   #58
82Diesel
Originally Posted by 93M6Formula View Post
Also got a new windshield installed, not many pics from the install but it looks great.
Put new bushings in my low mile leaf springs I acquired. A hole saw works pretty well instead of burning them out and smelling like burnt rubber. Also used my sawzall to cut the remaining shell out and then tap them out. All in all took me an hour surprisingly.
Very good idea on that bushings... i don't really know if i want to remove my LF springs or not... Hm.
Btw what did you use to clean up your Cluster Gauges, and circuit board + Everything else? Thx
82Diesel is offline   Reply With Quote
Old 08-25-2020, 10:52 AM   #59
93M6Formula
I used a damp micro fiber cloth and lightly dabbed the faces to pick up dirt. The paint is real delicate so you can't wipe it or it will smear, this worked pretty well. My lense was pretty decent so I just washed in soap and water. I was going to buff it out otherwise. For the printed circuit, I cleaned up the contacts with mineral spirits and a q-tip. It worked okay but my original circuit was pretty bad so I used one out of my donor cluster and cleaned that up instead. For the needles I just used some needle paint I got on Amazon, was a tad too bright to be correct but it looks fine.
Old 09-10-2020, 09:56 AM   #60
93M6Formula
Not a lot to update but my stock radio seems to have a loose connection somewhere so I decided to clean up a spare cassette deck I had.
Old 09-10-2020, 08:31 PM   #61
82Diesel
Nice radio. Mines still Stock & even works! so did my speakers. I've saved up a bunch of them bcuz the are hard to come by even so More hard to find the Rear cab speakers 4x10s. As Optional most trucks didn't have em.
Old 09-12-2020, 01:43 PM   #62
Corts60
Just here to tinker
Corts60's Avatar
Looking great! I love the stance and tires. Makes me miss my '80 4x4.
I love that you're keeping the diesels alive. I daily drove my '78 for years with the factory Olds diesel. Nothing wrong with getting 23mpg in a square body!
Old 09-14-2020, 09:29 AM   #63
93M6Formula
Yeah I have a whole pile of them just in case, I just like the stock look too much and I have a bluetooth adapter anyway so I try to keep the original radios.
Old 09-14-2020, 09:33 AM   #64
93M6Formula
Thanks! And yes I agree, I've always been a fan of the diesels and I hate seeing them swapped all the time, it's nice to be able to afford to daily drive one of these. This was a super original truck when I got it which I liked, it just got rusty. Original engine runs great, especially after what i've done.
Old 09-21-2020, 10:44 AM   #65
93M6Formula
So I kinda sorta changed the direction of this project. I had mentioned that I have the whole other chassis that i'm going to completely overhaul so I can continue to drive and enjoy this truck and eventually when the frame, axles, fresh engine etc was done I was going to transfer the body to that frame and obviously fix the rust beforehand.
Then I got thinking, this truck as it is, is kind of special and I would really hate to take away a lot of the originality. It's pretty much 100% mechanically and i've been already going through and fixing cosmetic things while leaving it looking original. So basically, I decided i'm going to continue fixing this up but as a driver that can have scratches and a little "patina" to preserve some originality and i'm going to build a whole other truck off to the side the way I really want.
I have nearly every part including a very solid cab from the parts truck I posted earlier that i'll use and build from there. I probably won't get far on it this year yet so I won't start a build thread just yet. I will be focusing on this truck for now and getting it where I want it in the meantime. Why not have two squarebodys right?
Old 09-21-2020, 10:48 AM   #66
93M6Formula
I did do a little this weekend to it.
Some emblem restoration
Old 09-21-2020, 10:54 AM   #67
93M6Formula
I'll have to take some better pics, and some may laugh, but I spent some time sanding down the passenger rocker and cab corner and repainted it, yes with the bottom half of the cab corner rotted out lol. I had my local Advance Auto mix up my paint code in a few rattle cans and let me tell you, I cannot believe how perfect it is, I don't think you could match 38 year old paint any better so that made me happy. It's part of my plan to try and preserve what I can for now and make it look much better.
The passenger door is the worst part on the truck now and unfortunately I don't think it's worth the time to try and patch up so i'm going to use one of my spare doors and paint it up. I'm confident I can get it to match the rest of the truck pretty well so it won't be too noticeable which is my biggest concern.
Old 09-21-2020, 11:05 AM   #68
93M6Formula
Eventually I may do the whole bottom half of the Almond color. Most of the original Bronze is in decent shape after a buff job.
I did score some hydro clutch pedals and an NOS GM door panel from my uncle which i'll use on the other truck.
Also, since manual tilt columns seem to be a tough find, I decided to see how close my GMT400 column would be since I have a few. Looks to be basically plug and play for 84+ trucks. It's about 2 inches longer where the steering shaft connects but that would be easy to remedy, and also the firewall flange is welded to it instead of seperate so I will just have to cut it off. Figured this would be good info for people. 78-83 trucks will just have to wire up the highbeam switch and wipers which would be simple or you can leave it alone.
Old 09-21-2020, 11:53 AM   #69
straight6chevyguy
straight6chevyguy's Avatar
I think this is a great idea. Yep you can always use another squarebody lol.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 09-21-2020, 12:36 PM   #70
93M6Formula
Exactly!
Plus this color really grew on me and along with other reasons, I would just hate to tear it apart and completely change it. I'll do what I want to the other one without feeling guilty lol.
I've always wanted one in dark metallic blue so that's what i'll be doing along with building my spare 6.5 and throwing the NV4500 behind that.
Old 09-21-2020, 05:17 PM   #71
93M6Formula
Here's some additional photos of how painting rust turned out lol. I can't complain, it's better than it looked before. The rocker is in one piece but was getting pitted as you can see but I didn't want to spend too much time making it perfect. Down the road i'll likely do corners and rockers as this cab is pretty solid yet.
Old 09-21-2020, 08:25 PM   #72
Corts60
Just here to tinker
Corts60's Avatar
That turned out great! They got those mixes spot on!
Old 09-21-2020, 08:51 PM   #73
93M6Formula
Yeah i was blown away, i don't think you could get any closer. I'm real happy.
Old 10-12-2020, 02:58 PM   #74
93M6Formula
Got a couple things done before snow starts flying. After I rebuilt the front end there was still a ton of slop in the steering which I found out was a totally smoked gear box and rag joint. Replaced the rag joint and swapped a low mile box I had laying around and it's MUCH better. Also super easy, took all of 45 minutes.
Also had fuel leak in the valley i've been battling ever since I put it together. The primary filter would not seal no matter what I did and I believe the housing is just warped. I decided to just get rid of for now and run the secondary. Going to order a universal housing and mount on the firewall near the factory secondary.
Old 10-13-2020, 07:50 PM   #75
Corts60
Just here to tinker
Corts60's Avatar
FYI, the big filter is the primary and the one on the engine is the secondary. They make quadrant o-rings for those fuel lines I'm pretty sure to seal it inside the housing. Perkins diesel uses the same set-up. Take a pic of the end fitting when it is out of the filter housing. If there is a little pipe nipple at the end of the threads, it is designed for a quad o-ring to seal properly.
Also the filters have different micron ratings: primary might be around 15-30 microns and secondary is probably 10 microns. Don't run without secondary too long or you risk sending bigger particles into the injectors and shortening their life.
