Old 07-09-2020, 06:27 PM   #32
68Gold/white
Re: 1969 Custom/10 clean up
That pipe is a connection to the crank case. Originally there was a hose that hooked to it, for a draft tube (early days) for crank case ventilation. Later, and most usually, that has a hose on it that connects to an in line PCV valve, other end hooks to carb or intake vacuum source...
68Gold/white is offline   Reply With Quote
c10, europe, netherlands, rebuild, swapped
