Steering box and cooler installed
Installed a new steering box and cooler the cooler is a Little OEM piece for a ford truck
http://67-72chevytrucks.com/vboard/a...1&d=1594216593 http://67-72chevytrucks.com/vboard/a...1&d=1594216613 |
Re: Steering box and cooler installed
im going to ask the silly question, why did you need a cooler for the PS fluid?
Well are you running factory tires sizes, are you driving in heavy Traffic now and then.
This alone will make it better for the PS fluid to last longer make the pump last longer. Because the temp of a PS system are hot any time you can take out heat out there is + to it. Since you added the cooler you may want to add a filter for it too. Nice job
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#5 | |
It helps the seals last longer, and the pump work more evenly since the fluid won't thin out technically by heating up. I am not sure when it becomes nesacary, but brand F was quite into them in the 3/4 ton and above rating. |
#6 | |
If my memory is correct when you start getting to 225*, and definitely all in by 250*. Seals start becoming hard due to breaking down from excessive heat atleast in transmissions.
So I may need to do the cooler myself in my Willy's. The brand F ttb frame i have it on has a simple one that leaked. I plan to add 35" rubber so it looks to be a wise investment for longevity. Or I can let it leak for brand f rust proofing the under carriage. |
