Old 07-11-2020, 03:30 PM   #1
Idaho64GMC
adhesive removal- dash
Looking for recommendations to get adhesive off of the dash, previous owner had a carpet mat on the dash and had it Velcro or glued on, dash is in good shape but has big strips of adhesive all over it. What can I safely use to get that off without ruining the dash?
Idaho64GMC is offline   Reply With Quote
Old 07-11-2020, 09:35 PM   #2
Pano
Re: adhesive removal- dash
I would consider Goo Gone, but looks like they recommend hard vinyl only.
https://googone.com/howto/blog/does-...-work-on-that/
It may affect the color.
Pano is offline   Reply With Quote
Old 07-11-2020, 09:41 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Spray brake cleaner on a cloth, test in unseen area. If ok, wipe away..........
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-12-2020, 10:36 PM   #4
jocko
jocko's Avatar
another vote for goo gone. I believe brake cleaner will damage paint.
Old 07-13-2020, 06:10 AM   #5
4u2nv
Iv'e used Varsol ( paint thinner ) on stuff with good results
4u2nv is offline   Reply With Quote
Old 07-13-2020, 11:31 PM   #6
Pontiac1976
Pontiac1976's Avatar
I used that to but on a small brush or nail brush work ok but in later year may cause cracking to the dash if it soak in to the pad to much.
I all so used cup hot water and plastic razer blade in the high heat direct sun light lots of elbow grease and what energy work out.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-14-2020, 07:10 AM   #7
Dead Parrot
Normal automotive vinyl cleaner.
Hot soap and water.
Rubbing Alcohol.
Dead Parrot is offline   Reply With Quote
Old 07-18-2020, 02:37 PM   #8
Idaho64GMC
Thanks for the tips, I'll try some of these options and post the results for everyone
Old 03-22-2021, 05:49 PM   #9
Vicente Aceves
Have you had a chance to try out any of those products on your dash?
I’m in the same boat as you. Old glue all over the dash.
Vicente Aceves is offline   Reply With Quote
