Old 06-28-2004, 12:47 PM   #1
dubie
dubie's Avatar
How does this come off??
I need to replace this temp sensor. How does it come apart from the coiled wire?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-28-2004, 12:58 PM   #2
71swb4x4
71swb4x4's Avatar
When I replaced mine it was all one piece, it included the sensor and the wire to the gauge.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-28-2004, 02:35 PM   #3
cdowns
cdowns's Avatar
pull sideways toward the wire
Old 06-28-2004, 02:59 PM   #4
junkyardjohn
junkyardjohn's Avatar
DUBIE... I THINK WHAT YOU ARE DESCRIBING IS A SENDING UNIT WITH A CAPILLARY WIRE PERMENANTLY ATTACHED TO THE SENDING UNIT & THE GAGE. IT'S A MECHANICAL GAGE AS COMPARED TO AN ELECTRIC GAGE, WHERE ONLY A WIRE (PROBABLY 14 OR 16 GA.) IS HOOKED FROM THE GAGE TO THE SENDING UNIT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-28-2004, 04:05 PM   #5
dubie
dubie's Avatar
It is a 1 piece emchanical gauge setup that the PO installed in this truck. I have an electric sending unit here that I would like to hook up to the the factory gauge. Was the wire "green" for temp sensor on our trucks??
Old 06-28-2004, 04:29 PM   #6
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Dubie,
My '69 C10 had the stock electrical temp sending unit on the 6 cyl, and the wire to it was green, with the funky little sideways plug on it. I plan to hook it to the sending unit that came in my '84 SB, which has the spade plug, so I guess I'll need to put a new end on the wire.
FYI, I'm planning to keep the electrical temp setup for the idiot light (no gauge package), and run a mechanical sending unit from the SB's thermostat housing for the underdash gauges. The housing has 2 extra holes from all the smog crap (which has strangely come up missing?!?!?), so it should allow me to run both.
Keep at it...I'm watching your progress, and about 20 steps behind you...
SSOW
stickshift_or_walk is offline   Reply With Quote
Old 06-28-2004, 05:06 PM   #7
rickspickuppart
Good one John, I wouldn't have even thought about it having a mechanical unit.
Shawn
rickspickuppart is offline   Reply With Quote
Old 06-28-2004, 05:55 PM   #8
krue
Designated A-hole!
krue's Avatar
Mine is the small green wire on the engine harness.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-28-2004, 06:47 PM   #9
Randy70C-10
Randy70C-10's Avatar
Just jerk it and it will come. Hmmmm, I could have worded that differently.
Randy70C-10 is offline   Reply With Quote
Old 06-28-2004, 09:06 PM   #10
crazy longhorn
Fabricate till you "puke"
LOL! if you jerk it enough times it jusy might Just couldnt pass that one up crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
